Old 03-09-2017, 01:53 AM   #1
87Skier
87Skier's Avatar
DBW Accelerator pedal
I want to keep the factory pedal in my 72 (without altering or just welding the pad onto the new pedal), is there a remote pedal, similar to this TCI TPS,
that plugs into the TAC module?
If not, I might be looking at an older engine or converting a newer one to work with a cable.
Thanks!
PS: looking at an LM7 using the factory computer.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 03-09-2017, 02:37 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: DBW Accelerator pedal
Why not just switch the throttle from dbw to dbc if your wanting to keep your factory pedal..that's what I did on my lq9
Old 03-09-2017, 01:27 PM   #3
Hart_Rod
Hart_Rod's Avatar
Thanks!
Take a look at this: http://67-72chevytrucks.com/vboard/s...d.php?t=651123
Hart_Rod is offline   Reply With Quote
Old 03-09-2017, 04:07 PM   #4
87Skier
87Skier's Avatar
Originally Posted by Hart_Rod View Post
I do not want the drive by wire pedal. I want to keep my original pedal.
I'll probably be going this route, and following this guide: http://www.lt1swap.com/cable_conversion.htm
Old 03-09-2017, 04:29 PM   #5
Hart_Rod
Hart_Rod's Avatar
This looks pretty original to me, . Bolts into the factory location and uses the factory pedal pad and trim.
Old 03-09-2017, 05:55 PM   #6
mongocanfly
Post Whore
Dang skier..I just glanced thru that link you posted and my heads swimming..I'd have to read thru it when I get time...all it took me to swap from dbw to dbc was to swap the throttle (butterfly) on the intake..i used one from a 99 camaro ..the guy that setup my ecm programmed it for bdc and my harness was built for dbc..all I had to do was plug it in..and ad a throttle cable..fairly simple
Old 03-10-2017, 08:53 PM   #7
87Skier
87Skier's Avatar
That's only if you have a newer ECM and harness and don't want to buy another ECM, harness, etc...
I just remembered why I wanted to go with DBW: cruise control. Do you have cruise control? Not really sure how GM did cruise control for drive by cable applications.
Old 03-10-2017, 09:44 PM   #8
mongocanfly
Post Whore
Mine is a 2002 model lq9 from a escalade..I'm sure it had cruise..but my truck doesnt and i didnt want cruise anyway..I used that 2002 ecm from that engine and a psi harness built for dbc...any reason why your dead set against dbw pedal?
Old 03-10-2017, 09:49 PM   #9
mongocanfly
Post Whore
Here's some stuff on dbc cruise..http://67-72chevytrucks.com/vboard/s...d.php?t=413973
Old 03-10-2017, 10:01 PM   #10
87Skier
87Skier's Avatar
Mine is a 2002 model lq9 from a escalade..I'm sure it had cruise..but my truck doesnt and i didnt want cruise anyway..I used that 2002 ecm from that engine and a psi harness built for dbc...any reason why your dead set against dbw?
I'm not dead set against it by any means. I just don't want to part with the my original pedal. I know it seems crazy/weird, but its a slippery slope and I decided that I want my interior to look original as possible.
Old 03-10-2017, 10:39 PM   #11
ls1nova71
ls1nova71's Avatar
I totally understand the wanting to keep the interior looking as stock as possible, that's the way I like them too, but you can make the DBW pedal match and be almost completely unnoticeable. I think mine looks pretty stock and is DBW.
But if you want to go DBC I have a write up on hooking up the cruise control. http://67-72chevytrucks.com/vboard/s...d.php?t=511477
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-10-2017, 10:43 PM   #12
mongocanfly
Post Whore
I understand keeping original..I'm trying to keep my 53 interior as original as possible but it will have a dbw pedal in it..I'm still torn on my brake and clutch pedals...I like the way they look and work thru the floorboard but I may have to give in and firewall mount-em
Old 03-10-2017, 10:46 PM   #13
mongocanfly
Post Whore
Harts and ls1s setups are nice..and like they said almost can't even tell it ..put your stock pedal on it and let-er rip
Old 03-14-2017, 09:15 PM   #14
jessemthompson
This is my DBW pedal with HartRods bracket. Sitting in the drivers seat it looks pretty factory.
jessemthompson is offline   Reply With Quote
Thread Tools
Display Modes
