03-09-2017, 07:27 PM | #1 |
TCC hook up on 04 GTO PCM?
I need to know which wire to use for a tcc hook up. The 04 gto pin out list 2 different tcc wires
GY/RD 422 TCC Solenoid Valve Control BN 418 TCC PWM Solenoid Valve I would guess this is like others 12v until braking then 0v. Which connection and what's the other wire for? Are there any wires on the transmission that I will need to check or modify? Thanks |
03-10-2017, 04:43 AM | #2 |
Re: TCC hook up on 04 GTO PCM?
Jweb,
Looking at the diagrams on lt1swap.com I think both 422 and 418 go to the transmission to control the TCC solenoid. http://www.lt1swap.com/pictures/Auto...20Controls.gif I think the brake switch signal you are looking for goes here on C1-33 http://www.lt1swap.com/pictures/Powe...p%20Inputs.gif It looks like its wired as a normally closed switch, so 12v off the brake and then 0v when brake applied. |
03-10-2017, 10:41 AM | #3 |
Looking at the pinout that wire is for the cruise control. I wonder if does both?
03-10-2017, 09:02 PM | #4 |
03-10-2017, 09:32 PM | #5 |
Thread Tools | |
Display Modes | |
