Old 03-12-2017, 01:52 PM   #1
BigRed63
BigRed63's Avatar
Step side running board bracket
On my 63 C10 step side I recently purchased, the seller put in 2x6 wood bed. In doing this he raised the bed up 1 inch to accommodate for the thicker pieces of wood. Now there is a 1 inch gap between the running board and the bracket. My question is what would be the best way to correct this? Should I shorten the bracket, put in a spacer, not really sure how to move forward with this and any input would be greatly appreciated.
BigRed63 is offline   Reply With Quote
Old 03-12-2017, 04:36 PM   #2
mehoff400
Re: Step side running board bracket
myself i would put a 1" spacer
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 03-12-2017, 05:50 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Myself I would take the wood out and do it right. Good luck!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-12-2017, 06:19 PM   #4
PGSigns
PGSigns's Avatar
I would also replace the wood.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-13-2017, 03:05 PM   #5
Lugnutz65
Lugnutz65's Avatar
People today are bigger and weigh more than in the 1960s. IMO, these brackets are not designed for someone who might weigh 240lbs. Last thing you need is seeing the step bracket fail when someone steps on it. They will look at you like it's not their fault and now you have a big problem.
The above suggestions are good but I'd also add another bracket just to prevent damage from "uncle Bob" who weighs too much. My 2 cents.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 03-13-2017, 04:44 PM   #6
andyh1956
I would cut a piece of Oak & make a spacer & be done with it.
andyh1956 is offline   Reply With Quote
Old 03-13-2017, 04:45 PM   #7
BigRed63
BigRed63's Avatar
Thank you for your suggestions, I will see what all I need to do in order to lower the bed back down and how much a new wood bed would cost. I didn't even think about using a second brace... something to think about
Thank you
Thread Tools
Display Modes
