Old 03-13-2017, 02:48 PM   #1
Nomadicflyer
Nomadicflyer's Avatar
72 C20 Camper Special Shocks?
Hello, All! I hope you and your projects are well.
I've searched and found little to go on, here. Sorry if this question was recently discussed. I have a 72 C20 with the Camper Special (Or do I? SPID attached).
I can't find all kinds of things for this thing, due to the options. Currently, I'm fighting new shocks that don't fit. The rear shocks mount points are 1/2 inch bracket dog ears at the top, 5/8 inch mount stud at the bottom. The shocks I pulled off seem to be modified (steel bushing punched out of the rubbers on lowers).
The shocks NAPA have listed are 1/2 inch upper and lower bushings, and would need punched out at the bottom mounts to fit my truck. I don't want to do that if there's a better option.
I'm guessing the issue arises from the heavy duty front and rear suspension parts listed in the SPID. I'm guessing the Camper Special option, although the only thing that says Camper Special concerns wiring. Without the heavier gear, I'd bet the auto parts offerings would conform a little more to the machine.
Anyone have an off the shelf option that works? Figured I would ask before I start modifying parts or the truck, or installing shocks that are under rated for my application. I do haul and tow, this has been my work truck for decades.
Thank you all,
Now to track down the brakes hoses that no one seems to carry.......
Kevin
1972 C20 Fleetside "Miss Olive"
http://67-72chevytrucks.com/vboard/s...d.php?t=721563
Nomadicflyer is offline   Reply With Quote
Old 03-13-2017, 10:46 PM   #2
Nomadicflyer
Re: 72 C20 Camper Special Shocks?
So if it helps anyone, this is what I went with....
Rancho shocks 5113, which came with the bushings to fit both 5/8 and 1/2 inch attach hardware.
https://www.napaonline.com/en/p/RS_RS5113
These work for my 72 C20 with the heavier front and rear coils, possibly otherwise knows as Camper Special.
Old 03-13-2017, 11:18 PM   #3
HO455
Post Whore
HO455's Avatar
Last week I was able source a rear brake hose from NAPA for my half ton Burban. Part number 36683. I was unable to confirm this was the correct hose at the store or online until I went to the compare hose function and then additional specifications became available and I could confirm the hose. There are different hoses for coil and leaf spring trucks with coil spring hoses being longer. I'm sure there's a joke there somewhere!
There is some more info at the end of the my Working Man's Burban thread as to fitting sizes. Just be aware that mine is a half ton and there may be a difference.
Good luck!
RIP Bob Parks.
Thread Tools
Display Modes
