Spot Welds????
I am wanting to remove the brackets that hold the fuel tank that are behind the seat in 63 C10. About 4 bolts are easy but how do I remove it where it's spot welded to the back of cab and the floor??? Have any of you done this before??? Thanks for any help....
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Spot Welds????
Very carefully with a spotweld drill/cutter. You can also use a die grinder with a ball shaped carbide burr.
Re: Spot Welds????
I sanded till the spot welds show really good then used a spot weld cutter, which looks like a miniature hole saw. It was easy..
Re: Spot Welds????
I started by sanding the area to find the spot welds...then I used a center punch to locate ..then I placed a small drill bit to start the cutter just to keep it centered.
might be overkill but keeping the cutter centered in the spot weld can be a problem without it wanting to walk out..
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
Post Whore
![]() Join Date: Mar 2013
Re: Spot Welds????
Not to hog the thread, but sand blasting would reveal the spot welds right?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Re: Spot Welds????
Another idea: http://67-72chevytrucks.com/vboard/s...70&postcount=8
Re: Spot Welds????
http://www.harborfreight.com/3-8-eig...ter-95343.html
You can unscrew the black part & flip it over if the teeth chip out. Try to keep perpendicular to the spot weld to avoid breaking the teeth. |
Re: Spot Welds????
Thanks everybody plenty of good choices...... Thanks Again....
Thread Tools | |
Display Modes | |
