Old 03-17-2017, 06:50 PM   #1
bigrigpardo
master cylinder help needed.
ok this is a conglomerate project I am working on on the side. its a 56 Packard clipper that I am doing a conventional power brake conversion on a poor mans budget. lol. I am using an 83 Camaro booster which has fit very nicely were I need it and am hoping to use a 67-72 drum/drum master but need one without the deep hole in it. I need a drum drum master that looks like the one on the right in the pic without the deep hole. everyone they pull up on the computer at the parts store is a reman with the deep hole. whos got a part number I can check out.
bigrigpardo is offline   Reply With Quote
Old 03-17-2017, 07:43 PM   #2
bigrigpardo
Re: master cylinder help needed.
or a part number for the adapter that turns a deep recess master into a shallow?
Old 03-17-2017, 11:47 PM   #3
B. W.
B. W.'s Avatar
I looked but couldn't come up with a number. I had the same problem with a dodge plow truck a couple weeks back. (needed a shallow hole M/C but had the deep hole M/C on it and it had no brakes - go figure!)
Would it be possible to make a longer push rod?
B. W. is offline   Reply With Quote
Old 03-18-2017, 06:24 PM   #4
rustytruck50
rustytruck50's Avatar
I fought the same problem on my '72...the double bail cylinder in those pictures is for disc only....I picked up the same one at Autozone and fought no pedal after bleeding several ways. The single bail for the cap that runs length wise is the one you want.
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 03-18-2017, 07:51 PM   #5
donandal
Summit Racing sells something like this...
probably other places also.
You will need to know the bore diameter and length needed.
"brake cylinder push rod extender"
the o-ring holds it in place, but you might need to notch the o-ring
a little bit to let air out of the hole when you push it in.
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 03-19-2017, 10:55 PM   #6
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
Look up CPP products.I had a oddball project with a 1 and 1/8 master cyl. and it came with that adapter with it.Something about power brakes or manual but Ididnt use it with my manual setup.
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline   Reply With Quote
Old 03-20-2017, 01:41 AM   #7
BCOWANWHEELS
just buy a 1970 non power m/c, there for drum/ drum brakes
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Thread Tools
Display Modes
