Old 03-22-2017, 04:03 PM   #1
67/Heaven
67/Heaven's Avatar
292 main crank add on pulley
Does anyone have a source or a vendor where I can purchase a single grove add on to my main pulley?
67/Heaven is offline   Reply With Quote
Old 03-22-2017, 04:26 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: 292 main crank add on pulley
How many grooves do you need? GM made a 3-groove, p/n: 10141202, that was standard for 292 L6s in HD applications.
Old 03-22-2017, 04:30 PM   #3
67/Heaven
67/Heaven's Avatar
Its a two grove but would like to add one on rather than to change the whole thing, any ideas
Old 03-22-2017, 05:00 PM   #4
RichardJ
Adding one to the front has the advantage of retaining the outer ring of the harmonic balancer when it goes bad. Putting a white paint mark on the timing notch and extending it out onto the new, outside pulley will let you know when the HB has begun to slip.
I did a quick internet search, as I'm sure you did and couldn't find one that said it would specifically fit the inline chevy six.
Find an old wrecking yard that still has 70-80s cars. Buick, Pontiac, Olds, Nova used the inline 250 up to the mid 70s and the Camaro up till 79. Many of those had PS, AC and smog pumps and used an add-on pulley. That's where I found mine.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 03-22-2017, 05:06 PM   #5
67/Heaven
67/Heaven's Avatar
Thanks for the info will do, I have also read that the SB add ons will work but I am not sure
Old 03-22-2017, 05:29 PM   #6
RichardJ
If you get one from a wrecking yard, you can also get the water pump pulley that matches
The first picture shows my 3rd HB. The first two dropped the HB outer ring on the road while driving. it also shows the water pump pulley that I picked up at the same time. You just have to be mindful of the HB groove spacing compared to yours. May want to take the HB as well, if it looks good.
A couple of years later when I added the AC, all the pulleys were ready to go.
Old 03-22-2017, 06:10 PM   #7
Grumpy old man
Grumpy old man's Avatar
I just this past week bought one from Clatterville trolly single bolt on crank pulley for $22.00 shipped put a WTB ad up .
Grumpy old man is offline   Reply With Quote
Old 03-24-2017, 01:39 AM   #8
'68OrangeSunshine
The Truck and Car Shop in Orange, CA has them for BBC and SBC. Might fit.
Thread Tools
Display Modes
