ticking noise in trans
i have a TH 400 TCI new from summit in a 72 c10 2wd big block with about 50 easy miles since restoration i installed the speedo cable with no problems,when driving there is a ticking noise in the rear area of trans.when on jack stands in neutral and spinning the driveshaft you can hear it.any ideas? thanks in advance
Re: ticking noise in trans
possibly a binding speedometer cable
![]() Join Date: Mar 2003
missing return spring on parking pawl lever?
i'd bet on the tranny dust shield hitting the flexplate should go away after it is worn thru
I'll go with the speedometer cable.
#6 | |
![]() Join Date: Jan 2016
thanks for the help,forgot to mention the speedo reads 10mph too slow and the odometer reads 400 miles but the truck has about 50 since build,no problem installing speedo cable.
![]() Join Date: May 2013
converter bolts are suspect
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
![]() Join Date: May 2016
Just a longshot. When I put an automatic transmission in my truck. I used the old flywheel bolts from the manual transmission. They were too long and hitting The edge of the oil pan. This was on 82 Ford 150.
so i just disconnected the speedo cable and the noise is still there when in neutral and spinning the driveshaft.the noise is very faint not loud but going down the road its annoying it is defiantly coming from the rear of trans were speedo cable goes in. is the park pawl spring a big deal to check?
Have to drop the pan
thanks kwmech
#13 |
anything yet?
#14 |
check the speedo. gears.. I'll bet the drive (on tail shaft)and driven( the speedo cable goes into) gears are jumping teeth.. or the end of the driven gear shaft at the speedo cable connection is cracked and the square cable end it opening and closing that crack..
I'll bet on the 1st.. as many don't match the drive and driven gears as many times it'll require the tail shaft housing to be removed.. |
#15 |
thanks for all the help.no dust shield on there now and bolts not hitting.a friend came over and turned the rear wheels and we have it narrowed down to the speedo gears,[if thats the problem] after we did some snooping on this site i have to come up with the tire size and rear end ratio and oder the correct gears and seals, take off the rear nose cone on the trans. and the housing the cable goes into and replace the gears.
#16 | |
#17 |
ok thanks JAMES
#18 |
A cracked gear on the out put shaft sounds very plausible.
As the clip might/would hold the peices together on the shaft. If it still did it in neutral did the noise get slower?
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#19 |
i never did try to put it in neutral to see if the noise changed i will try it though thanks
#20 |
i removed the speedo housing that holds the driven gear, looked in the trans.and the drive gear looks fine also the driven gear is fine but it still makes the ticking noise even with the housing/driven gear off.
#21 |
Well, it's been a week....anything?
#22 |
kwmech i gave up,the gears look fine it still makes the noise with the driven gear off,must be something else.thanks
Thread Tools | |
Display Modes | |
