05-02-2017, 12:34 PM | #1 |
3 Blade Clutch Fan Question
When i got my 85 Chevy K10 it had a 305ci engine with a 3 blade clucth fan. But when i swapped out the 305 to a 350 i went with a 6 blade flex fan from the auto store cause i was young and it was shiny and cool. I'm now trying to restore my truck back to more of a stock look. I'm curious if the 3 blade fan was stock on a 305 at the time, or was it a replacement as i'm not seeing a replacement 3 blade fan on any of the major 73-87 parts sites. Should i just upgrade to a 5 or 6 blade clutch fan? Any input would be appreciated.
05-02-2017, 01:09 PM | #2 |
Re: 3 Blade Clutch Fan Question
It was stock, but many people upgrade to the 5, 6, or 7 blade clutch fans.
05-02-2017, 04:29 PM | #3 | |
On another note, I ran a 17" Derale flex fan with big rectangular blades on a 350 with AC for many years with no overheating issues. However, I wouldn't run one with the type blades that narrow down towards the ends.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 05-02-2017 at 04:38 PM. |
05-02-2017, 06:57 PM | #4 |
So I bet you most likely had a single core rad w/ 3 blade small clutch, no a/c 305 Trans TH350 ?
would that be close. If your towing you might have two core rad 3 or 5 blade fan med clutch. If you had a M/T you would most likely have a smaller rad cooling. what do you use the truck for mostly, what temp seem to be the normal in your area. If your drive it like a car. All most never load it up, you would not need extra cooling.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
05-02-2017, 08:08 PM | #5 |
My truck had a 3 blade fan clutch on it, my truck also had the 350 with HD cooling, but no AC.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
05-03-2017, 07:11 AM | #6 |
Truck came factory with a 305, 700R4, and no A/C. I believe the radiator is a two core. The truck is just a summer cruiser, occasioonal wood hauler, don't really tow anything with it. The temps here in the summer range from the 70's to 90's usually. Truck seems to run about 210 deg with a 195 thermostat in it, but does heat up a little if it sits in traffic for a bit. But cools right back down once it starts moving again. Mainly just want to replace the flex fan to get it back stock looking and to remove the parasitic drag. I'll start looking for 5 or 6 blade clutch fan.
05-03-2017, 08:55 AM | #7 |
rodkill engine masters had a good episode on fans
05-04-2017, 08:28 AM | #8 |
Just watched that episode, yet another reason to ditch the flex fan.
05-05-2017, 12:56 AM | #9 |
To make sure the fan pull the best amount of air, the fan blades should be 1/8" to 1/4" passed the lip of the fan shroud.
05-08-2017, 08:46 AM | #10 |
Went to a swap meet this weekend, picked up a 7 blade clutch fan, a 3 blade clutch fan, and an original looking fan spacer. I paid $5 for the 7 blade fan, and a $1 each for the 3 blade and the spacer. I didn't need the 3 blade fan, but the clutch on it looked almost new, so i figured for a dollar i'd have a spare clutch in case the other one was junk. Now i just need to find some correct studs, as i don't believe i kept the originals.
Thread Tools | |
Display Modes | |
