05-20-2017, 04:54 PM | #1 |
2 inch lift suspension use stock pitman arm?
I am in the process of using stock leaf spring mounts and shackles and 2 inch lift springs from tuff country. The truck has a high steer kit. The pitman arm is bad. Can I use the stock pitman arm or should I get a dropped pitman arm for steering?
05-20-2017, 06:10 PM | #2 |
Its a Truck Thing......
Re: 2 inch lift suspension use stock pitman arm?
I talked to Tuff Country and they stated that 2 inch and below lifted leaf springs can use the stock pitman arm. Don't know about the high steer kit.
I am installing their 2 inch kit on my blazer. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
06-07-2017, 12:01 AM | #3 |
Are you happy with the ride and how it drives with the 2 inch lift?
06-07-2017, 07:26 AM | #4 |
The easiest way to know is to look at the drag link once you get the springs on....it should be as close to level or as parallel to the ground as possible....the more angle it has.....the more it affects the steering...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
06-07-2017, 09:28 AM | #5 |
I had bump steer with that 2" lift and changed the arm to correct it. I didn't have high steer but I suspect it would need it even more. Like A71Blazer said, the drag link must be parallel to the ground.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
06-07-2017, 06:47 PM | #6 |
Haven't done the swap from diy4x b52 and shackle flip to stock hangers yet but when I do ok let u all know how it goes
06-10-2017, 07:16 PM | #7 |
Do you have crossover steering and high steer (raised tie rod)? Typically do not see high steer without crossover, but sometimes crossover without high steer. Stock draglink is very short so axle movement will affect steering geometry more. Crossover- by moving the draglink attachment point to the opposite side it becomes much longer affecting geometry less.
If you do have crossover steering, I would say a dropped pitman arm is not necessary with a 2" lift. It may actually cause interference problems.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
06-10-2017, 07:24 PM | #8 |
Right now with the lift kit it has a 4.5 inch dropped pitman arm I'm going to try to find a pitman arm with as less drop as possible
Thread Tools | |
Display Modes | |
