Old 05-21-2017, 08:28 PM   #1
HBlue
78 Silverado-- PS squeal
The truck has not had much use over the last several years, but I decided to put it back on the road.The power steering has had a terrible squeal for too long, and has a small leak at the shaft on the steering gear. It squealed for about 10 to 20 seconds from a cold start. It squealed sometimes when steering and badly again at hard left and hard right.
I replaced the PS pump and took a lot of time to bleed the system. That did not eliminate the cold start issue so I removed the alternator belt and found I had a bad bearing in the alternator, so I replaced that.
Sometimes I still get a short squeal from a cold start.
Is that small leak allowing air to enter the system and causing the squeal?
Do I need to replace the PS gear or maybe just the seal?
HBlue is offline   Reply With Quote
Old 05-22-2017, 06:58 AM   #2
Dead Parrot
Re: 78 Silverado-- PS squeal
My first though was belt squeal from old or worn belts.
If you can get a helper to start the truck while you listen, you might get lucky and find the culprit.
Dead Parrot is offline   Reply With Quote
Old 05-22-2017, 08:08 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Check belt alignment and put a properly tensioned new belt on it. It sounds like the old PS belt is glazed.
Old 05-22-2017, 09:41 AM   #4
Jstock85
Agree. Belt may be the problem.
Jstock85 is offline   Reply With Quote
Old 05-23-2017, 10:10 PM   #5
HBlue
Thanks to all that replied.
I replaced the PS and the ALT belt.
No squeal at all now for the full range of steering.
Old 05-24-2017, 09:12 AM   #6
Jstock85
Good deal!
Thread Tools
Display Modes
