68 sending unit
So I recently replaced my gas tank and sending unit in my 68 c10 because my old one was a rust tub. I'm curious if anyone can help me wire up my sending unit cuz my gauge has always read at the 3 o'clock position.
![]() Join Date: Feb 2004
Re: 68 sending unit
Happy 4th. Usually if the needle showed past full the connection from the tank --tan wire- has no ground- infinite resistance --completely open circuit.
If nothing has changed at the gauge and the fuse on the block for fuel is ok, with the key in on position, touching the tan wire to a solid ground should show on the gauge ---empty. If this is so --- make sure the new sending unit housing on one of the top 5 or 6 screws has a permanent jumper wire to a solid ground. The tan wire connects to the nutted stud on top of the gas tank sending unit. The sending unit controls the ground resistance --depending on amount of gas in tank--- back to the gauge. You can test the new sending unit out of the tank with the jumper wire to ground , the tan wire on the stud, and moving the float slowly up and down before you put in the tank and before putiing gas in the tank. If you get needle movement in the correct directions -- probably good to go. Usually from my experience, if the gauge reads past full ---gauge is probably ok.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 07-04-2017 at 07:42 PM. Reason: words |
Re: 68 sending unit
Ok thanks so basically I just run the tan wire from behind the dash to the nut on the sending unit?
Re: 68 sending unit
Please post pictures if u got any it would help a lot
Post Whore
![]() Join Date: Feb 2016
Re: 68 sending unit
I did a quick search and got this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=640615
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Thread Tools | |
Display Modes | |
