Old 07-27-2017, 04:05 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
What's this brake component called?
Though I'm approaching a full take-off, as I've said before, somehow I've avoided ever doing a brake job. At any rate, what is the unit called where the rear brake line tube connects?
While at it, what's the "plate" bolted onto the axle called.
Thank you,
Novice
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-27-2017, 04:08 PM   #2
harpo231
harpo231's Avatar
Re: What's this brake component called?
wheel cylinder , backing plate
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 07-27-2017, 04:21 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What's this brake component called?
Back side of the wheel cylinder that puts pressure to the brake shoes.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-27-2017, 04:26 PM   #4
71CHEVYSHORTBED402
Wheel cylinder and backing plate........Noted, thank you
Tony
Old 07-27-2017, 04:31 PM   #5
harpo231
harpo231's Avatar
Np
Stan
67 swb BLU MULE
Old 07-27-2017, 04:41 PM   #6
71CHEVYSHORTBED402
I should have asked beforehand, how about the "equivalent" for the fronts, only disc brakes? I get to pull those lines next.
Can't wait to dive into the brakes (ha), and that's coming in somewhat short order. I hear they're easy. I don't know, looks like a lot of parts, but doable. Plenty of videos on the web.
Tony
Old 07-27-2017, 04:49 PM   #7
harpo231
harpo231's Avatar
lines hook into caliper , rotor mounts on spindle
Stan
67 swb BLU MULE
Old 07-27-2017, 05:24 PM   #8
71CHEVYSHORTBED402
Thank you again. Appreciate it.
Tony
Old 07-27-2017, 06:50 PM   #9
franken
Only take one side drum setup apart at a time--that way you can look at the other side when you don't remember where all the bits go...
franken is offline   Reply With Quote
Old 07-27-2017, 08:36 PM   #10
71CHEVYSHORTBED402
That and I'll be taking some pictures, thank you.
Tony
Thread Tools
Display Modes
