Old 07-29-2017, 10:52 PM   #1
Rob68c10
Which 73-87 3/4 or 1 ton trucks have the beefiest front brake setup?
I have a 68 GMC that I am going to swap a 73-87 front suspension and crossmember into. If I am going through the trouble of swapping, I want to try and find the beefiest brakes available, as this truck will be a tow pig. Any suggestions? Or are all the setups pretty much the same?
Rob68c10 is offline   Reply With Quote
Old 07-30-2017, 12:29 AM   #2
kwmech
Re: Which 73-87 3/4 or 1 ton trucks have the beefiest front brake setup?
Dually 1 ton, of course will be the beefiest. Other than that I would think any other 1 ton in a single wheel would suit you
Old 07-30-2017, 01:51 AM   #3
andrewmp6
Or there is many aftermarket kits out there for the 1/2 ton.
andrewmp6 is offline   Reply With Quote
Old 07-30-2017, 11:47 PM   #4
cheepin
Single wheel and Dually wheel front brakes are exactly the same. Same caliper, same rotor. Different part numbers but specs are the same.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Thread Tools
Display Modes
