Old 08-19-2017, 02:21 PM   #1
custom10nut
custom10nut's Avatar
Rear slider install pointers
I did a thread search for this but didn't find anything pertinent.
I'm finally replacing my reward window with a slider that I ve had for about five years now.
I have the stainless trim in the seal now and the replacement seal I have is the one for it.
I know I've read to put the trim on the seal before install.
I have the rope to pull the seal into place.
Is this a two person job?
Do I need to put any soap on the seal to help?
I'm just looking for any expert do's and donuts, so that I don't break it and it doesn't leak.
custom10nut is offline   Reply With Quote
Old 08-19-2017, 02:56 PM   #2
truckster
truckster's Avatar
Re: Rear slider install pointers
I would say it's a two-person job - one inside the cab pulling the rope in, and the other in the bed holding the glass in place.
I like glass cleaner better than soap because it's easier to clean up.
Some masking tape across the trim can help keep it in the gasket while you install the glass.
It's really not a very difficult install. Double-check your alignment before you start pulling the rope through. It's extremely difficult to break the rear glass.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 08-19-2017, 04:39 PM   #3
custom10nut
Thanks for the tips.
What is the best way to start it?
I'm thinking, put the bottom in, while holding it in place, slowly pull the rope starting from the center, working around to the sides, then back to the center on top.
Is this the right way to do it?
Old 08-19-2017, 04:51 PM   #4
kcsa75
kcsa75's Avatar
Exactly. Start in the center on the bottom and work your way around. You might want to have a hook or other tool to help you around the bottom corners. Otherwise, it's should be take less than five minutes.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 08-19-2017, 08:29 PM   #5
huntznsam
Bookmarked this for future use. I'll bet 80% or better applies to your job. I like the tip of wrapping the tape to the inside and letting the rope cut it.
https://www.youtube.com/watch?v=SOU_0HpS7To
HuntzNSam
huntznsam is offline   Reply With Quote
Thread Tools
Display Modes
