Old 08-19-2017, 07:20 PM   #1
CG
BlahBlahBlah
Burb/Panel ride quality
If you just want a super smooth ride and you are running 15 inch tires with plenty of sidewall would you be fine with the usual lowering using spindles and springs, or would air ride make a huge difference? No desire to be lower than a 4/6. I just keep reading about how nice the ride is on bags. Might be an unnecessary expense though.
Old 08-19-2017, 08:00 PM   #2
PGSigns
PGSigns's Avatar
Re: Burb/Panel ride quality
The spring rates are all about the same and your limited to 4" rear springs for the back. I feel like the shocks are the key. I have tried several sets and like the belltech street performance shocks I have on my 66 now. The seat can also make a change in the ride. When my seat was redone and i went from the cotton pad to the two layers of foam they used in was a big change in comfort. I have also started looking at tire ratings on tirerack.com. They have good ratings on tires and rate comfort. There are a lot of side wall and tire construction differences in the same size tire and it can make a big change in the ride. So for my Burb I am going to work it all as a system and see how it does.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-09-2017, 07:06 PM   #3
GIZZ
GIZZ's Avatar
What did you decide for your panel?
I'm also going to run 15's with a 4/6 drop. I'm about to order ball joints. Trying to decide if I want to run the original solid bushing control arms or run the newer rubber ones? What did you end up using?
GIZZmotorsports on YouTube & my panel truck build
'69 c10 panel, '75 c35 flatdeck car hauler
GIZZ is offline   Reply With Quote
Thread Tools
Display Modes
