Old 08-31-2017, 12:28 AM   #1
shibbby911
56 chevy rear end width?
Any one know the width on the stock rear end? I'm looking to find a used rear end or buying a new rear end that is close to the stock width. The one I have right now is to wide. I'm needing one that will tuck the wheels with out having to tub the bed 15x7 with 4.25 back space
shibbby911 is offline   Reply With Quote
Old 08-31-2017, 07:52 PM   #2
mr48chev
mr48chev's Avatar
Re: 56 chevy rear end width?
This says 62 but that seems wide. I have a 55 rear axle that I can measure tomorrow if no one chimes in.
http://www.carnut.com/specs/rear.html
My ongoing truck projects:
Old 08-31-2017, 08:55 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
47-55 1st is 57.6" front, 60" rear....55-59 is 60.5" front, 61" rear...This is per the "Standard Catalog of American Light Duty Trucks" by Krause Publications
Old 08-31-2017, 09:04 PM   #4
mongocanfly
Post Whore
here's a similar thread..(complete with ogres spellchecker turned off) haha...http://67-72chevytrucks.com/vboard/s...d.php?t=516720
Old 09-02-2017, 08:37 PM   #5
shibbby911
I was told to run a 71-80 Camaro or trans am rear end.any one running one?
Old 09-02-2017, 08:44 PM   #6
shibbby911
Old 09-02-2017, 09:00 PM   #7
mongocanfly
Post Whore
Old 09-02-2017, 10:42 PM   #8
mr48chev
mr48chev's Avatar
Those year Camaro rears fit pretty well and the later ones usually have disk brakes.
One thing though, don't buy new wheels for it until you have the axle installed and figure out what back spacing, width and what not are going to work out the best and still give the look you want. It's a lot easier to buy the wheels to fit the setup than change the setup to fit the wheels you have.
Old 09-03-2017, 03:20 PM   #9
idbeast
Originally Posted by idbeast View Post
The Fronts are 18X8.50 with 4.5 backspacing 5X4.75 bolt pattern.
The Rears are 18X9.5 with 5.25 back spacing 5X4.75 bolt pattern.
On the rears if you are running the Camaro rear end 60", wheel mount to wheel mount, you need 4.25 back spacing... that took some time and effort to figure out!!!
I'm going with a Ford 9 inch so it wasn't important to me, but I bought some one inch spacers and my wheels fit perfectly! Also the stock tires are 27 inches tall so I did tubular control arms with 1 1/2 inch shorter springs and 2 inch drop spindles.
I dug this post up, I stuffed 11" of tire and wheel in a 12" space and NO wheel tubs! I put 1" wheel spacers on each side so I could test fit everything and double check exact measurements for when I order my Ford 9"
idbeast is offline   Reply With Quote
Old 09-03-2017, 05:19 PM   #10
Russell Ashley
Russell Ashley's Avatar
I have an 80 Trans Am disk brake rear in my 57. My wheels are eight inch Corvette rallys which I believe have four inch back spacing and they are perfectly centered between the fender and bed. They have plenty of room and never rub. I thought it was 62 inches flange to flange.
Russell Ashley is offline   Reply With Quote
Old 09-03-2017, 11:28 PM   #11
59chev
59chev's Avatar
I am going to be running a 77 Camaro rear in mine. It's a 3.23 Posi unit with Drum brakes.
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Thread Tools
Display Modes
