Old 09-04-2017, 02:49 PM   #1
aotte1
Rear Control Arm Bushings?
Deciding which bushing to use for rebuilding rear control arm bushings.
Rob at Nolimit suggested not using polyurethane in this application. Not sure why, or what he recommends for a fun street driver.
Also considering spherical bearing if available.
Hotchkis swival max is being considered strongly.
Any suggestions on what you are using, and how it drives, will be a big help.
Thanks, did not find much in FAQs or search on this.
Les
aotte1 is offline   Reply With Quote
Old 09-04-2017, 05:55 PM   #2
69gmcc10
69gmcc10's Avatar
Re: Rear Control Arm Bushings?
I installed the polyurethane bushings, they seem fine. Rob says they will bind and rubber would be a better choice because they flex more. The heim from hotchkiss would be the best from a performance stand point, but I don't know how they would effect ride quality or if that is even a concern of yours.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 09-04-2017, 06:31 PM   #3
aotte1
69 GMC,
Thanks for description of what you did and how it drives/rides.
Les
Old 09-05-2017, 03:58 PM   #4
SCOTI
SCOTI's Avatar
The spherical/Delrin style joint would be top choice. Factory replacement rubber 2nd. Poly bushings last.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-06-2017, 01:00 AM   #5
aotte1
SCoti,
Thanks for your suggestion, helps a lot.
Will go with the spherical ball....
Les
Thread Tools
Display Modes
