Active Member
![]() Join Date: May 2016
Hissing from brake booster
I have a 71 k15 that while running has a hiss from the brake booster? unless my foot is on the brake pedal. Brake pedal pressure seems fine. Is this something that I should be concerned with or perhaps the start of a problem?
Any advice on what I should check? |
![]() Join Date: Mar 2003
Re: Hissing from brake booster
Change the booster, cracked diaphram. Will lean out the engine and eventually fail
Moderator
![]() Join Date: Jun 2017
kwmech is spot on...change out the booster before it fails on ya...
Active Member
10-4 Thanks for the help
Thread Tools | |
Display Modes | |
