Old 10-04-2017, 11:49 AM   #1
Nanook
Nanook's Avatar
Factory Original?
I came across the following ad for an "original 64 K10", my question is would a SWB be available with 3/4 ton axles from the factory? (Below is a copy of the text from the ad.) I posted this in the 4X4 section also but was looking for as much feedback as possible as I was thinking of purchasing this truck.
My best research would indicate that this is a unaltered 3/4 ton SHORT BOX frame and chassis - although it COULD even be a ONE ton version. VERY VERY RARE either way!
ORIGINAL UNALTERED SHORT BOX PERIOD CORRECT FRAME! ORIGINAL SUSPENSION - lift blocks and all components are stock and unaltered. .
Over load (dual) rear leaf springs.
Front Differential: SPICER 44 with 12" brakes and "Power Train" locking hubs. Rear Differential: EATON model H011 heavy duty with 4:56 gears. Indestructible rear end type - popular with tractor pullers. Full floater.
Transfer case: Original Heavy-Duty TIMKEN #221.
NICE CLEAN interior with original seat. No mice smells!
1/2 ton BODY/sheet metal. Beautiful STRAIGHT tailgate! Box rail tops near PERFECT condition. Even the roof drip edge still has the caulking in tact all the way around! Needs cab mounts, rockers, front fenders and hood.
Extra front clip - SUPER STRAIGHT!
NICE RARE PROJECT!
EXTRA PARTS including the original transfer case and drive shafts (3).
First $4500.00
No trades - unless you have some original GOLD COLOR 67-72 Chev truck sheet metal parts (hood, tailgate, doors and passenger side front fender)
Honest Seller.
Nanook is offline   Reply With Quote
Old 10-04-2017, 12:30 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Factory Original?
From what I understand you could get almost anything you wanted on an Ordered vehicle back then. Notice the COPO Camaro and such. Is there a build sheet behind the seat?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-04-2017, 12:44 PM   #3
Nanook
Nanook's Avatar
Just got the vin on this...4C144J160136...so not a factory 4X4.
Old 10-04-2017, 01:59 PM   #4
oldusafmsgt
oldusafmsgt's Avatar
No 3/4 ton short beds, 2 wheel drive or 4 wheel drive 60-66 from the factory. 3/4 and 1 tons were available long wheelbase chassis only. Those 3/4 ton axles were added, or a long bed was shortened, but I doubt it. People have been putting 3/4 ton axles in K10's for years.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 10-04-2017, 02:19 PM   #5
72cs20
In other words, his "best research indicates" means "I just made this up".
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 10-04-2017, 02:49 PM   #6
oldusafmsgt
Yup, the VIN says it was originally a 1/2 ton 2 wheel drive. A made up truck. Not "very, very rare" as the owner states. It will never be worth what a "factory original" K10 or K20 is. In my opinion , it's worth 2000.00 tops as a project truck.
Old 10-04-2017, 08:32 PM   #7
spacedebris
How good can the research be when the vin will tell what it is and you still cant tell? Any simple google search on the vin number would have told if it was 1/2 3/4 or 1 ton and 2x4 or 4x4
ORIGINAL UNALTERED SHORT BOX PERIOD CORRECT FRAME!.
In other words not the OE frame but a frame from the same era. So if the frame has been changed then likely most of the other suspension and rolling stock has been changed too and are NOT factory.
Honest Seller.
Yeah Right, if you have to say that you likely are not one. IMO
1960 c30 Apache Panel w/ '95 cummins bt6 turbo diesel (work in progress) NOTE: due to photobucket trying to extort money my photos are temporarily unavailable. currently looking for alternative to fix issue.
http://67-72chevytrucks.com/vboard/s...d.php?t=523009
spacedebris is offline   Reply With Quote
Old 10-04-2017, 11:09 PM   #8
Captainfab
60-66 Nut
The VIN on the frame will tell you what year the frame is. That is unless the frame was from a GMC. Then there will not be any VIN.
Old 10-05-2017, 12:31 AM   #9
TJ's Chevy
TJ's Chevy's Avatar
Just another guy trying to rip someone off unfortunately. Is cool though....but should knock a couple k's off that price.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-05-2017, 12:37 PM   #10
VictoriaHardware
VictoriaHardware's Avatar
Please tell me it does not have an L79 w/ roller cam
VictoriaHardware is offline   Reply With Quote
Old 10-05-2017, 02:55 PM   #11
Nanook
Nanook's Avatar
Nope....just a plain old factory 350 LT1 with a factory original 8 speed auto.
Thread Tools
Display Modes
