Old 10-25-2017, 09:49 PM   #1
blown luv
New guy with questions
Just picked up a 59 swb fleetside. Nova clip and rear end. Bags on the rear. 1st question I wanna swap it to a 55-57 front end. Will the 59 inner fenders work with 55-57 fenders? Will post some pics soon.
blown luv is offline   Reply With Quote
Old 10-26-2017, 12:16 AM   #2
Foot Stomper
Foot Stomper's Avatar
Re: New guy with questions
Nope. Inners are different as are many other things. Should've bought a 567 and bolted on a 58/59 fleetside box...much easier.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 10-26-2017, 09:14 AM   #3
agnes the dog
agnes the dog's Avatar
I originally wanted the 55-57 when I found my 59. I did some research on swapping the front end. While it can be done, I would suggest waiting a while before you make the decision to swap. I have grown to be extremely fond of my 4 eye and wouldn't think of changing it now.
Just because you can, doesn't necessarily mean you should.
1959 3100 stepside 355 + T5
agnes the dog is offline   Reply With Quote
Old 10-26-2017, 03:45 PM   #4
59chev
59chev's Avatar
Another thing to keep in mind is the wheelbase. When the clip job was done, depending on where the wheelbase was set, the tire might look too far forward in the 567 fenders.
Due to the shape of the 58-59 fenders, builders generally push the wheelbase further forward on a 58-59 to make the tires look centered in the fender opening.
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 10-26-2017, 05:44 PM   #5
dsraven
the 567 trucks have a whole different front section, including a longer frame to accommodate the longer fenders etc. the rad support brackets are also in a different place on the frame. I went from a 58 frame to a 57 body. the cab etc is the same but the rest of the stuff in front of that is different. in your case the frame extensions for the bumper would need to be cut off a bit, about 2 inches by a guess, and the rad support frame brackets would need to be moved back some but otherwise it should work, depending on where the suspension clip was terminated and the new frame horns were added for the bumper. the cab and front wheel axle center line didn't change so the wheels would look the same in the openings as far as center line is concerned but the shape of the openings is a bit different so, like 59chev says, watch the "look" with a tire on that is the final overall size you will be using. mock it up and see, not much to undo for a body clip swap. use some wood blocks on the frame for a fake rad support height and go for it. worst case scenario you stick the old front end back on.
post some pics. we could see what you are working with.
Old 10-26-2017, 11:30 PM   #6
blown luv
Thanks for all the replies. What's the truck to posting pics? It ask for a URL?
Old 10-27-2017, 12:37 AM   #7
mr48chev
mr48chev's Avatar
On posting photos. click on go advance down at the bottom of the quick reply and when the next page comes up Click on th paper clip to the right of the smily face at the top. That opens up a manage attachments page and you go from there.
Just thinking, a subframed truck may not be as hard to swap noses on as a stock frame truck but you will still have to do a lot of sheet metal trimming before it's over.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 10-27-2017, 08:57 PM   #8
blown luv
Size:  41.8 KB my fiddy9
Old 10-27-2017, 09:19 PM   #9
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice looking 59!
ChuckDriver is offline   Reply With Quote
Old 10-27-2017, 09:29 PM   #10
dsraven
the frame on the 58-9 trucks is 2 1/2 inches longer out front. not a big deal to cut off and drill a couple new bolts for the bumper. the rad support has to move back as well.
Old 10-27-2017, 10:15 PM   #11
blown luv
Thanks . Doesn't sound to bad , now to find a 55-57 front end.
Thread Tools
Display Modes
