10-27-2017, 02:25 PM | #1 |
Motor Mount
Putting a small block in place of the 292, where can I buy a frame motor mount to replace the right side one on the 292?
10-27-2017, 02:56 PM | #2 |
But Found Her 25yrs Later!
Re: Motor Mount
Keep an eye on the 60's and 67-72 parts forum section.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
10-27-2017, 02:58 PM | #3 |
Re: Motor Mount
Then there is also this guy:
http://www.aspenautoaz.com/60-66-chevy-truck-parts.html
10-27-2017, 03:07 PM | #4 |
Re: Motor Mount
Actually, you might be better off just getting the 73-87 mounts. They are far superior.
http://67-72chevytrucks.com/vboard/s...ghlight=Mounts
10-27-2017, 03:12 PM | #5 |
Re: Motor Mount
10-27-2017, 11:26 PM | #6 | |
60-66 Nut
Re: Motor Mount
The '67-'72 230/250 engine mount brackets are the same as the '63-'66 230/250 and small block brackets
If you go this route, you will want the brackets from a C20 or C30. Those fit the early frames better than the brackets from a C10. And yes those are a far superior engine mount Quote:
10-30-2017, 09:36 PM | #7 |
Re: Motor Mount
Good luck on your engine swap project. If you don't need the old 292 mount ( or 292 engine ) please consider posting it in the parts for sale section as they are somewhat rare and there are people that need them ( I know because I have been that guy in the past).
Thanks, Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
10-30-2017, 11:01 PM | #8 | |
Re: Motor Mount
12-27-2017, 09:57 PM | #9 |
Active Member
Re: Motor Mount
I might be able to use those mounts PM me
Thread Tools | |
Display Modes | |
