Old 11-01-2017, 10:06 PM   #1
coldgin
3/4 ton disc brake conversion
wanting to do a disc brake conversion on my 69 gmc 3/4 ton....it is a 8 lug drum with 4wd....what options do I have?thanks for any input
coldgin is offline   Reply With Quote
Old 11-01-2017, 10:22 PM   #2
jocko
jocko's Avatar
Re: 3/4 ton disc brake conversion
71/72 K20 front swap would do the trick with all stock parts. No easy options for the rear that I'm aware (if you're indeed asking about a 4 wheel disk swap, not just fronts). There was a company awhile back, blackbird, or something like that, that made a kit, but they've been out of business for a little while. If you google on here, there are several threads about it - none very encouraging though that I recall.
EDIT: might be worth reading this thread, has some info: http://67-72chevytrucks.com/vboard/s...d.php?t=735442
EDIT2: If you happened to have done a 73+ 14 bolt conversion, there are options/kits available.. http://www.ruffstuffspecialties.com/catalog/14BSRW.html
EDIT3: Never heard of this guy before, but he has 67-72 D60 rear disk kits - which probably doesn't help you either, am assuming you have an HO rear. But anyway - http://lugnut4x4.com/
ACTUALLY - OOH, just found this, have NOT seen this before, Lugnut also seems to have Eaton rear disk kits.... !? Anyone used one? NOW I'm interested http://lugnut4x4.com/product/62-72-e...onversion-kit/
Old 11-01-2017, 10:48 PM   #3
coldgin
yes front only....my bad
Old 11-01-2017, 11:01 PM   #4
jocko
jocko's Avatar
Copy, no worries. Looks like Lugnut has front kits also. Didn't check ruffstuff.
Old 11-01-2017, 11:58 PM   #5
randy500
If your dana 44 is closed knuckle then this thread should help you out.
http://67-72chevytrucks.com/vboard/s...d.php?t=567022
If its open knuckle then any dana 44 or 10 bolt 8 lug disc brakes from the knuckle out will bolt on.
Your outer axle shafts should be the same if open knuckle if not 10 bolt and dana 44 outers are the same, inner shafts are not.
randy500 is offline   Reply With Quote
Old 11-02-2017, 12:40 AM   #6
kwmech
If you can find a late model Suburban 3/4 ton front end, say from 88-91, that would be the sweetest swap. You will get the 3/4 ton stuff you want along with 30 spline inner axle shafts. Every bit as strong as the 44, maybe even a little more. Bolt right in.
Old 11-02-2017, 11:34 AM   #7
jeffahart
jeffahart's Avatar
What kwmech said. And, do some research. Because you have options, and if you leave your options open you will have a better chance of finding a good axle with your gears. Anything but converting that closed knuckle to disc, not worth the hassle, IMHO, when a straight swap is so easy. If you get a late enough axle the only part you will have to chase is to convert the metric soft line to original sae hardline. I kept rear drums, I like a solid emergency brake, drums in rear are good for me. I put a Dana60 in mine. I looked at quite a few 44s and couldn't find anything worth the bucks, everything I looked at needed to be gone through. I got sick of the process and ponied up some bucks for the 60 that I could bolt in without touching. I did a small post on my conversion you can check out.
http://67-72chevytrucks.com/vboard/s...d.php?t=641965
J
White K20
jeffahart is offline   Reply With Quote
Thread Tools
Display Modes
