Old 10-29-2003, 11:24 PM   #1
Shawn340
Question Help Guys
Hey guys you're awesome with all the info you all provide so heres my dilemma. I have a 83 fullsize blazer 4x4 when the temps start dropping around here(PA)my truck pulls hard to the right for about the first 2 miles of driving, If I let off the gas it will straighten out for me. I have replaced PS pump and lines, brake calipers, tie rod ends, and all bushings. I really hope you guys can help it really scary that first few miles. Thanks everyone
Shawn340 is offline   Reply With Quote
Old 10-29-2003, 11:32 PM   #2
Prerunner1982
Prerunner1982's Avatar
may check the air pressure. air pressure drops when it gets cold and your right front maybe lower than the rest until it gets rolling and the air inside warms up. just a thought. i maybe way off here.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 10-30-2003, 12:19 AM   #3
bigblock73
yeller
bigblock73's Avatar
Jon might be correct.
...or...
What lines did you replace? The pump lines, the lines going to the calipers, or both? I am thinking it can be in there somewhere.
..Jeff
bigblock73 is offline   Reply With Quote
Old 10-30-2003, 12:40 PM   #4
77bowtie
Laugh if ya want but when my 77 did that pulling to the side stuff, it about drove me crazy. Simple fix though. Back up in a straight line while pumping on the brakes. After a bit of readjusting the brakes like that the pulling to the side stopped. At least for me. Try it it can't hurt.
77bowtie is offline   Reply With Quote
Old 10-30-2003, 05:36 PM   #5
Ripley Bryant
Could be the E-Brake too. Had this happen on a Honda I used to own. there was a split in the E-Brake cable housing under the car. On cold days, any moisture that got in there would freeze, causing the cable to bind up. It would loosen itself up after a couple of miles of driving.
Worth a look. An easy test would be to not use the E-Brake (if you don't have to worry about rolling down a hill ) and see if you have the problem the next day.
Good luck,
Ripley Bryant
Salem, Oregon
'77 Chevrolet Silverado 20 - 454 BB, TH400, Factory wood floor longbed
'75 Fiat X1/9 - my AutoXer
'77 Fiat X1/9 - her AutoXer
'81 Fiat 2000 Spider - under construction
'00 Dodge Neon - Commuter
'00 Dodge Grand Caravan - Family bus
Ripley Bryant is offline   Reply With Quote
Old 10-30-2003, 08:02 PM   #6
86SILVERADO
86SILVERADO's Avatar
It also could be a caliper that is sticking and not retracting properly. To test front and back, drive for a bit and when it seems to be starting to straighten out, get out and carefully feel the calipers and drums. The problem area will be much hotter than the rest.
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
Old 10-30-2003, 08:18 PM   #7
Shawn340
Hey guys I really appreciate all the suggestions I will try them all. Thanks for taking the time to reply to my plea i will certainly do the same in the future for you guys. Thanks
PS: Bigblock I replaced the PS pump lines not the caliper lines. Not air pressure I stay on top of that all the time.
Thread Tools
Display Modes
