Old 11-05-2017, 06:14 PM   #1
Jeffh
Bed wood I need a favor .....
My stepdad is into wood working so using the specs from the GMC Paul site he has planed down some rough cut quarter sawn kiln dried white oak for my 60 short fleet side. Now comes the problem. My bed wood is so bad none of it makes a good pattern for anything. I need to know the location and curve to the board that goes around the wheel wells. Anybody have any good ideas or tips?
Jeffh is offline   Reply With Quote
Old 11-05-2017, 07:01 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Bed wood I need a favor .....
Here is the milling info: http://www.gmcpauls.com/47-72_BedWood_Info.htm
People who have milled their own: http://67-72chevytrucks.com/vboard/s...d.php?t=486504
In fact if you look at the FAQ section for "Bed Wood:" you will many, many threads posted there for our information and use - http://67-72chevytrucks.com/vboard/s...d.php?t=646002
Old 11-05-2017, 07:11 PM   #3
Jeffh
Yep, have the boards cut to length / width, have the groove routered into them, just need to know the second board over from the sides how to determine the section and curve that gets cut out of it for the wheel wells...
Old 11-05-2017, 08:02 PM   #4
PGSigns
PGSigns's Avatar
When I did mine I slid the boards in and got the gaps set on the entire set. When I was happy with the way they all set I marked the cut out using the wheel well as the pattern. Worked out perfect.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-05-2017, 08:30 PM   #5
jayoldschool
Moderator
Yes, you don't pre-cut the wheel cut outs. Make your wood, install, drop the tub on top, trace inside with a Sharpie, then cut the wheel openings with a jigsaw.
It's the first full length board on each side, and they both only get a partial cut.
jayoldschool is offline   Reply With Quote
Thread Tools
Display Modes
