Old 10-30-2003, 12:14 PM   #1
bigd65
bigd65's Avatar
A.I.R. system question
i am bidding on a set of dynomax headers on EBAY but i have a question concerning the A.I.R. system. the headers dont have the bungs for the system and i am planning to put the system back. i do have a CAT that has the pipe fitting for the A.I.R. is there a difference or does it matter if they go into the header or into the CAT. we have emissions here and i will need to put the system back on by MARCH/04. what do yall think
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 10-30-2003, 01:25 PM   #2
PHOENIX
If they do a visual inspection you will need the injection tubes at the header/manifold. They may let you get away with it in your area, but maybe not.
The factory manifolds do not inject into each runner (?) in the header/manifold. The edelbrock TES headers for these trucks do have an injection tube for each runner. I am sure this helps in the emissions performance.
Check with your local station to see if you do in fact need the a.i.r. system. You may only need the EGR, CAT, PCV, and vacuum canister.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 10-30-2003, 01:37 PM   #3
l3rian_King_196
Watch out on ebay when buying parts or whatever Bought 400 bucks in items and didnt get a thing for it.
l3rian_King_1967@yahoo.com
http://f1.pg.photos.yahoo.com/l3rian_king_1967
l3rian_King_196 is offline   Reply With Quote
Old 10-30-2003, 02:41 PM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
The A.I.R. stuff is supposed to be at the exhaust manifold/header. The purpose is to inject air into the exhaust stream early on to lean out the exhaust mixture right when it comes out of the heads, to make it burn hotter to help burn any raw fuel. Down at the cat, which I have never seen, will not be factory. If someone is critical of this, they will turn it down right off the bat.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 10-30-2003, 04:59 PM   #5
bigd65
bigd65's Avatar
ok Mike, i knew you would hit right on the head. THANX.
2017 Chevy Tahoe
Old 10-30-2003, 05:28 PM   #6
PHOENIX
Not only that but injection air into a cat can cause it to overheat and become a danger. It is a way to cheat if done correctly.
Old 10-30-2003, 09:06 PM   #7
bigd65
bigd65's Avatar
i think i am just gonna wait, i like the flowtech shorties with the A.I.R. bungs already in them. i think that will be my best bet. then i gotta find an A.I.R. pump with a serpentine pulley. i still have the hose and crossover pipe from original.
2017 Chevy Tahoe
Old 10-30-2003, 10:22 PM   #8
apstguy
LED King
apstguy's Avatar
The AIR injection into the cat started in the late 90's and involves a much bigger emissions control system. Leave it capped. It would only screw things up.
I would like to find a AIR pump with a sepentine pulley also. Anyone got any links?
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Thread Tools
Display Modes
