11-15-2017, 07:58 PM | #1 |
Oem help
Any help with finding out sway bar diameters for C/10 2wd 1/2 truck with drum brakes? Or end links length? Trying to order some new parts from POL. Thanks in advance.
11-15-2017, 08:13 PM | #2 |
Re: Oem help
Front 1'' 1/4'' Dia. / year 67-72 C/10
Rear 1'' 1/8'' Dia. / year 67-72 C/10 |
11-15-2017, 08:34 PM | #3 |
Re: Oem help
I hate to hi-jack but is the Suburban the same?
11-15-2017, 09:03 PM | #4 |
Re: Oem help
11-15-2017, 09:20 PM | #5 |
Post Whore
Re: Oem help
Are you referring to stock sway bars?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-16-2017, 02:59 AM | #6 |
70+ ( Old Skool Club )
Re: Oem help
Theses are not the measurements for the stock factory sway bars on 67-72's.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
11-16-2017, 08:52 AM | #7 |
Re: Oem help
Nor do they have end lengths that you can measure. The bar uses frame style mounts on the factory sway bar mounts AND it uses frame style mounts on the control arms for the bar.
11-16-2017, 09:57 AM | #8 |
Re: Oem help
I have one sitting in my shop off a 69 c10 if you need measurements
11-16-2017, 10:49 AM | #9 |
Re: Oem help
Great post here on the front bar and installion.I could be wrong but I do not think there was rear sway bar option from the factory on 67-72's.
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
11-16-2017, 10:52 AM | #10 |
Re: Oem help
Thanks guys. I am referring to stock sway bar and end links. I was trying to order some bushing from POL and asks for bar diameter and end link lengths...and the biggest offered is 1".
11-16-2017, 11:42 AM | #11 |
Re: Oem help
Mine are one inch
Stan 67 swb BLU MULE posted via flip-fone |
11-16-2017, 06:58 PM | #12 | ||
"I ain't nobody, dork."
Re: Oem help
I have a 1972 GMC C15 and the stock front sway bar is 1 1/16".
I upgraded the bushings to urethane from Energy Suspension. Kit came with the clamp housings, bolts, bushings and grease. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Thread Tools | |
Display Modes | |
