Old 11-22-2017, 03:29 PM   #1
bigmac73
bigmac73's Avatar
opinions please tranny swap
For months to years I have been kicking the can around about swaping to a OD tranny. I have looked at 700R4 and 200r4 and 4l60e and 4l80e ... On and On and then I stumbled across this
Midwest Muncie auto to man kit
https://www.midwestmuncie.com/produc...peed-swap-kit/
so in regards to the price , I figured if you went with a newer electronic OD tranny you would be close to the same cost by the time you got the controller and converter TPS adapter any what ever else...
I do not mind driving a stick and think they are more fun that an auto.
So guys check out the link and give me some thoughts
what was the TQ/HP rating for a Muncie tranny back in the day???
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 11-22-2017, 03:46 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: opinions please tranny swap
A nice rebuilt Muncie can be had for $1,100.00 the rest of the parts are cheap .$4,300.00 is the crazy price !
My buddy Rick has over 150 in stock and has been rebuilding them for builders for a long time .
Grumpy old man is offline   Reply With Quote
Old 11-22-2017, 04:33 PM   #3
rotten67
That's not going to give you an overdrive fourth gear will be 1to 1
rotten67 is offline   Reply With Quote
Old 11-22-2017, 05:44 PM   #4
clay68c10
clay68c10's Avatar
A Muncie would be neat, but I’d go for a tremec TKO. The trans is $2450 at speedway motors, you will have to come up with a bellhousing, clutch, linkage etc. The extras may put you close to 3500-4000 but you will have a strong overdrive.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Thread Tools
Display Modes
