Old 11-29-2017, 11:26 AM   #1
fredhlynch2
Steering Wheel Size
Want to change the size of my steering when when I put in the Ididit column. I thin the stock wheel is 15.5 inches? What do you folks change to, size/diameter wise, with a new column. Have rack and pinion power steering.
fredhlynch2 is offline   Reply With Quote
Old 11-29-2017, 11:57 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Steering Wheel Size
With power steering, you could go down to a 14" or 15" aftermarket one. In trucks I like 15" better as they look like the right size and not too small. I also like to rest my elbow on the window sill and it allows my hand to comfortably reach the wheel. I would not recommend anything smaller than the 14". I thought the original wheels were closer to 17" for leverage on non power steering trucks.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-29-2017, 12:44 PM   #3
fredhlynch2
Thanks for that. I alo think the 14 inch is too small. Will go with 15 inch. I had no idea the stock wheel was that large. You could steer a barge with that!
Old 11-29-2017, 02:06 PM   #4
Mine is the comfort grip wheel for a Camaro, 14". It is a nice size and has the look for this era of trucks. One note if you are not aware, pre 67 columns don't quiet fit modern wheels as well. The turn signal and horn cam clocking are off on the older ones. I happen to have a column/steering shaft from a 69 C10 in my 64.
Old 11-29-2017, 05:20 PM   #5
raidmagic
raidmagic's Avatar
Good info, thanks. I wasblooming atnwheels and was having a hard time finding one that fit. I'd like a bit bigger one the p.o. put a small one on there.
raidmagic is offline   Reply With Quote
Thread Tools
Display Modes
