Old 10-31-2003, 10:10 AM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
dually wheel question
Has anybody mounted dually wheels on a non-dually rear-end as found on a leaf spring K25(dana60)? Is an adapter required to move the inner wheel mounting away from the hub? I'd like to do this and keep the wheels tucked inside the wheelwells or at least not stick out any further than the fronts which will keep the 15x10 w/ 33s. I'd like to mount the 34-9.5/16 TSLs. Will I need a spacer between the two wheels? I was looking at these wheels:
http://www.southwestwheel.com/mywebs...89_2735344.htm
Will they work?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-31-2003, 01:27 PM   #2
jef5150
Inline 69
jef5150's Avatar
check these guys out,,,,,,, http://www.arrowcraft.com/ jeff
jef5150 is offline   Reply With Quote
Thread Tools
Display Modes
