Old 12-07-2017, 10:55 AM   #1
Bacca
Bacca's Avatar
Feedback on LED Bulbs
Hello looking for some feedback on use of LED bulbs running lamps, turn signals in a 1982 C-10.
Pros/Cons - Manufactures - Where to buy - Or not to buy.
Bacca is offline   Reply With Quote
Old 12-07-2017, 11:35 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Feedback on LED Bulbs
on my 81 I'm running all leds...some from lmc ,, some from ebay....if I couldn't find a dedicated led replacement for something like my interior light, I put in a 1156 style led bulb..
I highly recommend leds..low amp draw and bright as heck....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-07-2017, 12:06 PM   #3
Bacca
Bacca's Avatar
Thanks Mongocanfly!
Old 12-09-2017, 05:21 PM   #4
68longhorn
68longhorn's Avatar
Superbrightleds.com is the best source. Also check squared away customs on Facebook
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 12-09-2017, 07:25 PM   #5
Desert_Eagle02
Thinking about adding them to my 78, and the gauge cluster also. Do you have to install a resistor since the draw for the leds is a lot less than the regular bulbs?
1978 GMC K25
1984 Chevy Scottsdale K10 built 350 4"lift - SOLD
Desert_Eagle02 is offline   Reply With Quote
Old 12-09-2017, 07:48 PM   #6
mongocanfly
Post Whore
the leds didn't cause me any problems..I know some people do have issues but not on mine....got lucky I guess
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-10-2017, 12:01 AM   #7
bilfman
bilfman's Avatar
Caused me trouble on signals. Not enough amp draw to work the flasher. Now have 2 leds in the front and regulars in the back. Signals work but the green signal indicators can both be seen slightly lit. But only bright enough to be seen at night.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 12-10-2017, 01:49 AM   #8
layinrocker65
layinrocker65's Avatar
Does an electronic flasher not Fix that issue?
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 12-10-2017, 07:33 AM   #9
hatzie
Moderator
hatzie's Avatar
Sure does. Fixes the trailer/no-trailer issues as well. I've heard em called electronic or fixed speed relays. You can get drop-in units from your friendly neighborhood Borg retailers like Pep Boys, AutoZone, O'Rileys etc.
Wish it was that easy with the Gen 7 & 8 Impala and the 2014 Toyota Tundra pickups with the obnoxious BCM controlled flashers.
No need to buy Chinese LED lamps online. That time has come and thankfully gone.
Phillips and Sylvania could see where the winds of change were blowing and have actually put some engineering time into retrofit bulbs. Most cheap retrofit LED bulbs don't properly use the filament bulb reflector so you end up with a bright point source that doesn't reach out very far and the cheaply built bulbs don't have a decent heatsink so they don't last long. The Phillips and Sylvania offerings properly use the reflector and have decent heatsinks. This means the name brand bulbs will last longer than most Chinese bulbs and they don't cost that much more. The other big plus is you can buy the name brand LED bulbs at your local Borg retailers like Pep Boys, AutoZone, O'Rileys etc.
Look for Phillips VISION or Sylvania ZEVO.
Sylvania Zevo and Phillips Vision LED replacements for the 1156 single filament tungsten and 1157 dual filament Tungsten bulbs actually fire the light back at an angle into the reflector bowl to properly fill the light housing and project for other drivers to see you. They also have a decent size heat sink so they won't burn out in a year or two like tungsten filament bulbs and cheaply built LED bulbs.
The Sylvania ZEVO 2357 & 1157 bulbs are available in RED (1157) and AMBER (1157A). I have the AMBER versions in the front marker/turn housings on my trucks and the RED versions in the tail lamps. I have yet to see Phillips Vision 1157 series bulbs in AMBER 1157A replacement but I doubt it will take long for them to catch up.
I use the Phillips Vision Bright White 1156 bulbs in my Squarebody cab floor "courtesy" lamps and backup lamps. Phillips makes RED 1156 Vision LED bulbs so look at the package to be sure it says BRIGHT WHITE before you drop it in your shopping cart.
I use the Phillips Vision 921 LED bulbs for late model backup lamps that used the 921 tungsten bulbs. These fire the light into the reflector bowl as well. I have yet to see a Sylvania equivalent but I'm sure it's in the works. I can actually see behind my trucks, my Polaris Sportsman, and my Gen7 & Gen8 Impalas at night. They light the entire lens of the backup lamp with BRIGHT WHITE light to properly warn other drivers and project the light back against the dark. I installed the Phillips Vision 921 bulbs in my 74 year old parents Toyota Tundra pickups backup lamps as well.
I used the Phillips Vision 194 LED bulbs as 194 and 168 side marker bulb replacements Phillips claims they replace 194, 168, 12961, 158, 161, 193, and 579 bulbs. These are just LED bulbs with a frosted diffuser to spread out the light.
Phillips also makes a Festoon bulb to replace the interior cab light but mine is still the old fashioned Tungsten.
As with everything else the Asians have started to mimic the Zevo and Vision LED bulb designs... probably with the normal extreme drop in quality.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-10-2017, 02:00 PM   #10
Skunksmash
Skunksmash's Avatar
This. Go to superbrightleds.com. They have an automotive light selector. All the lights are designed to work with any year of car that they will fit. I had no trouble with the LED's for my 87, they worked the flasher just fine.
I'd recommend to anyone here, to buy their more expensive reverse lights for the 73-87. I never thought that the reverse lights on one of these old trucks could actually be useful. With those LED's in the reverse lights in my 87, I can see better when backing up than I can in my wife's new toyota. Its great.
Skunksmash is offline   Reply With Quote
Old 12-11-2017, 08:43 AM   #11
Bacca
Bacca's Avatar
Thanks everyone for your feed back. It's been very helpful. I haven't purchased any yet but will soon. I'm going to go with Hatzie's advice.
Again thanks all Bacca
Old 12-12-2017, 09:22 PM   #12
68longhorn
68longhorn's Avatar
Hatzie superbrightleds is not cheap but they are high quality and last. I have had their headlight bulbs for 2 years and markers and tails and interior bulbs for 4 years without issue
Old 12-13-2017, 01:02 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Superbrightleds.com is the best source....
Way to expensive. I have bought all of my LED bulbs from Amazon and paid 1/3 the price. They have a great site with good info, but ridiculously over priced.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-05-2018, 05:06 PM   #14
Desert_Eagle02
Getting ready to order LEDs for my gauge cluster. I haven't had a chance to take mine apart to see what kind of bulb it takes. Does anyone know? It's a 1978 GMC. I'm guessing it's the 194 bulbs?
1978 GMC K25
Old 01-06-2018, 01:32 AM   #15
RedBed
RedBed's Avatar
I think they are 168. I just put LEDs in my gauge cluster while I had it apart and they are WAY nicer IMO.
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic
RedBed is offline   Reply With Quote
Old 01-06-2018, 01:54 AM   #16
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
If I were to find some that lasted longer than three years I might be inclined to pull my dash apart again. I switched to LED's on every bulb on my '03 Ranger. Dash lights started flickering after a year and were all burned out after two years. Turn signal and taillight bulbs burned out after three years. Said to heck with it and replaced every bulb again with standard non-LED's. Guess I got ahead of the technology.
That said, I replaced all last year so these bulbs would have been bought four years ago. Half were from Amazon and the other half were from Superbrightleds.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 01-06-2018, 01:15 PM   #17
Desert_Eagle02
Ok thanks guys. Mine are pretty dim, and a couple are burned out. So I'm going to try some leds. Hopefully they last longer than 1-2 years.
1978 GMC K25
Old 01-07-2018, 12:09 PM   #18
jkk
jkk's Avatar
2Xx
jkk is offline   Reply With Quote
Thread Tools
Display Modes
