12-16-2017, 02:46 PM | #1 |
T Bird/Taurus Electric fan wiring
Hey fellas, anybody ran the 94 to 97 T Bird, Taurus electric fan in their rig? Just got mine feom Summit last night, and stupid me didnt see where it said nothing was included lol.. ive tracked down the 3 wire connector. But now its a matter of what else I need to hook it all up and make it work. I know some relays and probably a manual switch are in order, bit I'm trying to be as frugal as possible lol! Under $30 would be spectacular.
12-16-2017, 08:14 PM | #2 |
Re: T Bird/Taurus Electric fan wiring
Why that fan? Cost? I run a 3300cfm fan from Flex-a-lite Black magic https://www.amazon.com/Flex-lite-180.../dp/B000CNHFNA Fan control from Speedway Motors. https://www.speedwaymotors.com/Speed...uges,2356.html
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
12-16-2017, 08:23 PM | #3 | |
12-16-2017, 08:29 PM | #4 |
I had left over aluminum i made brackets from... 1x1 and flat but comes with own. You see fit on 62 og radiator. Price is what I posted. The speedway controler vs the flex-a-lite is better and hooks to water temp sender and not a probe through radiator. So if temp says 180 on gauge you set fan on off to it.
12-16-2017, 08:30 PM | #5 |
Get fan without controler, lower price and buy other controler. Or use on/ off toggle. Two wire fan.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 12-16-2017 at 08:43 PM. |
12-16-2017, 08:33 PM | #6 |
Those are original tabs for schroud.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 12-16-2017 at 08:39 PM. |
12-16-2017, 10:58 PM | #7 |
60-66 Nut
You might PM a moderator and see about having this thread moved to the electrical section. You will be more likely to find someone there with an answer to your question.
12-16-2017, 11:23 PM | #8 |
Com on man... I layed it out more than once. 2 wire, 3300cfm. Flex-a-lite BLACL MAGIC. Ran same fan on 1998 Dodge Durango Pre runner here in 120+ degrees but you all want a used pos ford junk yard special?
12-17-2017, 12:37 AM | #9 |
Lol true enough LV.. once i get all y'alls big budget, ill pick that up haha looks like this one goes back for some other cheapo upgrades until our Santa Barbara move. Thank you guys!
12-17-2017, 10:07 AM | #10 |
[QUOTE=sixty4bigwindow;8106563]Hey fellas, anybody ran the 94 to 97 T Bird, Taurus electric fan in their rig? Just got mine feom Summit last night, and stupid me didnt see where it said nothing was included lol.. ive tracked down the 3 wire connector. But now its a matter of what else I need to hook it all up and make it work. I know some relays and probably a manual switch are in order, bit I'm trying to be as frugal as possible lol! Under $30 would be spectacular.[/QUOTE
I used a fan from a Cougar XR7 with a 100 plus amp alternator and 80 amp relay. Been running this set up for 4 years with zero issues. Hope this helps. http://forums.corral.net/forums/gene...topics/1112478 |
12-17-2017, 11:40 PM | #11 |
No need to spend all that money on the flexalite. The Lincoln Mark VIII Fan, which should be the same as the T Bird fan, is plenty for these old trucks. They are very reliable and move a ton of air. I've had my truck in 115 degree heat, in stop and go traffic with the A/C on and not had the heat gauge rise above about half. It's a big 18" fan, I got mine for around $70. A decent 2 speed fan controller, or dual fan controller and you'll be set. If you spend much more than $150 or so, I'd be surprised.
My set up is a Mark VIII fan with a Dakota Digital fan controller and relays. You can set the exact temp you want it to turn on and off the high and low speeds and customize a few other settings as well. A couple years in and it's doing great so far. Sure you can spend $285 on just the fan...but why? It's rated for 3,300 CFM whereas the Mark VIII fan is shown between 4,000-5,000. |
12-18-2017, 10:16 AM | #12 |
This is what I used... they have a 200 degree switch as well. I do keep an extra kit in the glove box in case something fails. Has not failed in over a year. I have had no problems with the Taurus fan. Works great in high temps and easy to get an affordable replacement if necessary.
Partssquare Cooling Fan Thermostat Kit Temp Sensor Temperature Switch 40 amp RELAY KIT https://www.amazon.com/dp/B015R9AVMA..._JH8nAb02H5A5C |
12-18-2017, 05:02 PM | #13 | |
12-18-2017, 07:27 PM | #14 |
If you are talking about the three connector to the fan I picked one up at the pick and pull. Make sure you use heavy gauge wire. I used 10 gauge because that fan draws some amps when it first kicks on. You will also want to upgrade your alternator to at least a 12si. I installed a 100 amp out of a 97 Buick. Here is the wiring diagram that came with the kit. Also that is a 2 speed fan, I just wired to the high speed side.
12-18-2017, 10:03 PM | #15 |
This ia what i am going to use on mine.
12-18-2017, 10:53 PM | #16 | |
12-18-2017, 10:58 PM | #17 |
$100
12-25-2017, 10:44 PM | #18 |
'94-97 4.6L MN12 (Tbird/Cougar) fan here...controlled via the PCM through two of these relays:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
12-26-2017, 01:19 PM | #19 |
I used the Taurus Electric fan, BMW dual temp sensor and relays from a volvo 850 wagon to control all of it. There was also an auto reset breaker for the hot wire coming from the battery to the relays. Let me know if you need more details.
1965 C10 350 combo |
12-26-2017, 03:30 PM | #20 |
I'm not understanding the attitude of this post. The T-Bird fan swap is very popular among hot rodders. It's an inexpensive way to get a good cooling fan that works and is reliable. Just because you chose to spend 3 times the money doesn't make what he's doing "pos Ford junkyard special"
12-26-2017, 04:31 PM | #21 |
Thay dont like the f--- word on here?
12-27-2017, 08:58 AM | #22 | |
12-27-2017, 11:28 AM | #23 |
...not to mention that it moves more air than the "BLACL MAGIC". Lol.
12-27-2017, 11:45 AM | #24 |
12-27-2017, 04:23 PM | #25 |
28 years here.
Thread Tools | |
Display Modes | |
