Old 12-16-2017, 08:00 PM   #1
Kromie101
6 lug to 5 lug ???
So i'm trying to find out the easiest way to go from 6 to 5 lug. I've been told I can drop in a 71 to 72 rear. I thought I could buy new axles but not exactly sure what to order. I have a stock 67 c-10 rear in truck now. Any help on which way to go would great!!!
Thanks!
Kromie101 is offline   Reply With Quote
Old 12-16-2017, 08:27 PM   #2
Portland68
Active Member
Re: 6 lug to 5 lug ???
My dad and I spent a Saturday bolting in a rear end from a 1972 truck, the only difference is about an inch in width (I forgot which is shorter). Assuming you have trailing arm rear suspension the hardest part was freeing up the rusty bolts.
Portland68 is offline   Reply With Quote
Old 12-16-2017, 09:04 PM   #3
Kromie101
Ok cool,thank you. Just need to find one.
I found axles on ebay but just not sure if they are the right ones.
Old 12-16-2017, 10:18 PM   #4
Mike C
Mike C's Avatar
Speedway Motors (among others) sells and axle/brake drum kit for less than $400 to convert yours. Just know that 67-70e and 70l-72 have different length axles and housings.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-17-2017, 01:20 PM   #5
GMC3
I had a machine shop re drill my axles for 5 lug. I think they also had to machine down the hub a little. Was pretty reasonable.
GMC3 is offline   Reply With Quote
Old 12-17-2017, 03:22 PM   #6
1969 Project
1969 Project's Avatar
I just replaced front 6 lug rotors to 5 lug rotors and replaced the rear axles to 5 lug, easy swap and not too expensive. I ordered everything from ECE.
1969 Project is offline   Reply With Quote
Old 12-17-2017, 10:13 PM   #7
Indyspecracer
If you haven't done so, you will need to convert to disk brakes up front. I would suggest getting spindles that will use your existing ball joints and tie rod ends. ECE has what you need. Rotors can be bought just about anywhere, 71-83 all use the same rotor.
I just bought a rear axle conversion kit that includes Axles, bearings, seals, wheel studs and brake drums from Summit for my 69. I went ahead and replaced the rear shoes, wheel cylinders and brake hardware also
Indyspecracer is offline   Reply With Quote
Thread Tools
Display Modes
