Old 12-22-2017, 03:18 PM   #1
cff
Active Member
Truck Clock.
JIf anyone is interested. I found a site that is selling new reoroduced Dash mounted clocks for $249US. They are for a 65 chevelle, but they look identical to a 66 chevy truck clock. Not sure what other years of truck are the same. Cheap alternative to buying an original. Look up Ausleys chevelle. Probably other sources too, but this is the first one that I found. Don't know if its quartz or not.
cff is offline   Reply With Quote
Old 12-22-2017, 03:33 PM   #2
cff
Active Member
Re: Truck Clock.
Just checked. It is quartz and comes with wiring and mounting bracket.
Old 12-22-2017, 10:50 PM   #3
rvrfoot
Re: Truck Clock.
rvrfoot is offline   Reply With Quote
Old 12-23-2017, 02:33 PM   #4
LT1 Burb
LT1 Burb's Avatar
Re: Truck Clock.
You mount yours yet in the suburban.
LT1 Burb is offline   Reply With Quote
Old 12-23-2017, 05:27 PM   #5
cff
Active Member
Re: Truck Clock.
No. Trying to figure out if it's supposed to be painted the interior color or if it would have been left black. And which would look better.
Old 12-24-2017, 04:25 AM   #6
GMCNUT
GMCNUT's Avatar
Re: Truck Clock.
Well thats an easy answer - they were installed just as you see them out of the box in all cars and trucks - black
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 12-24-2017, 01:20 PM   #7
cff
Active Member
Re: Truck Clock.
Thanks. Well then that's how it's going to be.
Hey GMC nut. Did the GMC pickup use the same clock?
Old 12-25-2017, 06:09 PM   #8
GMCNUT
GMCNUT's Avatar
Re: Truck Clock.
No, GMC trucks used this cluster mounted Clock pictured from 1960 through 1966
Thread Tools
Display Modes
