1971 cab and chasis dump truck
I have a 1971 c30 dump truck with plow I just bought. The front springs sit to low for me I would like to have as heavy duty of springs as I can and for the truck to sit up higher. I am going to rebuild the entire front suspension a long with the coil springs. What springs have others used?
Re: 1971 cab and chasis dump truck
![]() Last edited by Likethat; 12-29-2017 at 01:39 AM. |
Fabtech you can go springs or spindles.
Stan 67 swb BLU MULE posted via flip-fone |
You could also look at Big Block with Air conditioning,that would stiffen it up if you have a small block.
![]() ![]() Join Date: Jan 2015
That would be a good one to make a 4x4 out of
I have been thinking about 4x4. It has a 350 465. I have a couple t56s and a nv4500 4x4 laying around. I am leaning on keeping it 2wd till I finish filling my barn with gravel. Either way the suspension need replaced. Rock auto only show 1 spring opion for the front. I was hoping some one has got the front of these trucks up more thrn stock. The plow pf course causes aot of sag.
It's a fairly easy swap I did my 68 C/30
Before pic |
After
Just new coils would help and since you have the plow I'd go for the big block/AC springs. If the plow still drops the front end too much for you there are these snubber things they sell for tow trucks. www.awdirect.com sells them. They are like air bags but just rubber, but sealed for air pressure
https://www.awdirect.com/front%2Dmou...2Denhancement/
I read thru the 68 4x4 build a while back it was very good. I have been looking for a small dump truck and this one came up. I had been wanting a 67-72. I have had a 87 4x4 for about 20 years now so and older one is needed
![]() I see photobucket is up to its tricks what do you guys use to post picks that isn't photobucket. So you can see what I post and not p500 error. I have used BB A/C springs in a few cars over the years. I will check them out for the c30. I didn't know if there was a heavy/ super duty spring for the dump trucks. |
Trucks I have had:
79 c10 short bed 350 4bbl sm465 79 f150 4x4 460 4bbl c6 single cab short bed 8in lift 38 boggers 84 f350 4x4 460 4bbl t19 single cab long bed 4in lift 38 super swampers 91 f250 4x4 460 efi zf5 single cab long bed Still have 87 v10 4x4 350 efi sm465 single cab long bed 71 c30 350 2bbl sm465 dump truck |
axle code LV 0107 G
G=locker What gear ratio ![]() Last edited by Likethat; 12-29-2017 at 01:41 AM. |
#13 |
That is stamped on the axle tube? I never knew they'd be stamped if equipped with No-Spin. If that's true you just taught me something while trying to find something out. I don't see anything to indicate ratio. Bset way to learn the ratio is pull cover and get numbers off ring gear. Then you can put fresh lube in to keep that old HO on the street
#14 |
That is on a H072 in the dump truck it is on the passenger side of the pumpkin upper.
#15 |
Okay need rear spring for the 71 dump truck having a hard time finding the heavy duty spring pack any leads would be helpful as to where to buy. Looking for like 11k springs +/-.
#16 |
Would love to find rear sway bar from newer 1 ton dually complete bar and all mounts ubolt as much as possible.
#17 |
![]() Join Date: Nov 2008
I used these springs. My truck is a 72 C20 with a Cummins 6bt. Been installed for several years and no issues.
Can't remember what they are supposed to be for. I did a bunch of research at the time but have forgotten. Still have my sales receipt from Rockauto so I was able to pull the part number. https://www.rockauto.com/en/moreinfo...27&jsn=3&jsn=3
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
#18 |
Check out https://www.sdtrucksprings.com/. I've ordered from them multiple times to re-spring my work trucks and have been very happy with the quality. They have HD packs for the rears and options (if I remember correctly...) to add leaves to the pack. Worth looking into...
#19 |
![]() Join Date: Jan 2007
#20 |
I would love to have mine looking like Jeff's I'm definitely going to switch you to 4x4 one day right now I just need to haul gravel for a while.
#21 |
They're all cool!
Thread Tools | |
Display Modes | |
