12-27-2017, 11:15 AM | #1 |
engine noise on a fresh rebuild
I'm hoping that it's the cam and lifters. It mostly happens at start up.
https://www.youtube.com/watch?v=yD0-...ature=youtu.be https://www.youtube.com/watch?v=Y07M...ature=youtu.be |
12-27-2017, 11:44 AM | #2 |
It's Better With Nitro
Re: engine noise on a fresh rebuild
Your videos are unavailable to me, but my initial question would be what type of lifters do you have?
12-27-2017, 11:50 AM | #3 |
hydraulic
It's very loud at start up but it seems to be slightly noisy through my entire drive. Also, when I downshift and the motor revs up, it has a noise to it as well. At start up it literally sounds like a spun bearing. |
12-27-2017, 01:16 PM | #4 |
Take your oil filter off cut it open and see if you see any metal in the filter.
12-27-2017, 02:47 PM | #5 |
Which engine do you have? Does the oil pressure gauge work? Cold start up oil pressure after a few seconds on my 250 6 cylinder is about 50 psi with 10-30w oil.
A bad/worn bearing will lower oil pressure quite a bit.
Everybody has to believe in something. I believe I'll have another beer. |
12-27-2017, 10:00 PM | #6 |
I took the pan off and inspected all bearings and they look great!
Thread Tools | |
Display Modes | |
