Old 12-27-2017, 01:16 PM   #1
bigmac73
bigmac73's Avatar
anybody have an idea on cab weight
guys , dose anybody have on idea on the weight of a stripped Cab with the doors still on??
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 12-27-2017, 02:58 PM   #2
nightrider388
Re: anybody have an idea on cab weight
Between 450-500 lbs with glass and doors
nightrider388 is offline   Reply With Quote
Old 12-27-2017, 06:00 PM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I can say a stripped cab is much lighter than I expected. I recruited three guys who could bench 1000 pounds between them. I took a rear corner, and I'm 5'11", 155 lbs. and a "senior". We lifted and all four busted a laugh.
Just guessing here, but seems close: Stripped cab is 300 lbs. Doors 45 lbs. each, door window & vent with regulator etc. is 32 lbs. per side, windshield 25 lbs., large rear window 15 lbs.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-27-2017, 07:31 PM   #4
Mr Handy
Mr Handy's Avatar
sounds about right to me. I asked a few frineds to help me on a saturday and when all was said and done we had 6 to drop the cab back on the frame, 4 normal guys can do it, especially if the doors are off. I had the front and back glass in when we dropped it back on.
Mr Handy is offline   Reply With Quote
Old 12-27-2017, 08:04 PM   #5
mdemco
I am sitting here staring at my stripped cab, my buddy and I set it on sawhorses Saturday.
Had to pick it up half hunched over and crab walk it to the back of the frame, over the tires, then walk across the shop and set it down.
We guessed 260-280 lbs.
mdemco is offline   Reply With Quote
Old 12-27-2017, 09:01 PM   #6
71CHEVYSHORTBED402
Could be that 260-280. It wasn't a struggle at all. I've heard a bed weighs more than a stripped cab, and IMO, that includes a short bed without tailgate.
Tony
Old 12-27-2017, 09:19 PM   #7
Ramjet51
100% stripped cab without Dash is 236....must took one to recycle that was beyond help,
You'll never know unless you try
Ramjet51 is offline   Reply With Quote
Old 12-27-2017, 09:34 PM   #8
rockyrivermark
Be careful and get extra help.
I thought I was in Invincible lifting heavy things My whole life.
Weight lifting, working, etc.
then at 48 and in great shape ruptured disc in Lower back. It will cripple the toughest out there.
Careful!
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 12-27-2017, 10:41 PM   #9
Shinysideup
Shinysideup's Avatar
Careful!
Mark
I hear ya! Ripped a bicep lifting my side of a shortbed (2 ppl) because of changing angle of lifting. Not fun. Didnt feel likely, wasnt overweight in my young mind
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 12-28-2017, 12:24 AM   #10
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I used a 4x4 and an engine hoist, piece of cake and all 12 beers were mine! Two pieces of 1" x 5" 1/4" plate screwed to the 4x4 and a 6" bolt through the end of the hoist tube (place the 4x4 on top of the hoist tube and toggle it). Center it up inside the cab with a little hanging beyond the doors or door openings. Lift and put it where you want it...Can use the same 4x4 and hoist to lift the bed as well, center stake pocket is center of load...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Thread Tools
Display Modes
