New here - Intro & Question
New to the forum and new to 67-72 Chevy/GMC. Been a chevy man all my life. Owned many, many dimes over the years. Up until now, I never had the time & funds to jump in to an older project.
Picked up a 69 GMC a couple months ago. Sorry for the crappy pics. So far I've been working on sorting everything out and planning timelines for the work to be done. This will be a weekend driver, so I'm setting plans to keep this available for the occasional cruise around town. Truck is lowered, but it appears to be chopped springs all around. So I've ordered all the components for a 4/6 drop (2.5" spindles & 2 springs for the front) and 6" springs for the rear. Also went ahead and picked up disc brake setups for the front and back. I plan on keeping the 6 lugs, so I've currently been searching for wheels. That has run me into all kinds of questions on backspacing. I'd love to put a set of 20x9.5 all around, but from hat I gather, the backspacing may not work for the front. Link below, Legend 6 142 are 20x9.5 with BS of 5.75. I'm not sure how this will fit on the front. Thoughts? |
Re: New here - Intro & Question
Any thoughts on 20x9.5 up front with 5.75” BS? Do I need something closer to 4.75 or 5.25 BS on the front? Would I be looking at running a spacer?
I am a Referee of life.
Your drop spindles will widen the stance of the front. It's usually about 3/4 in each side. The 71-72 rear end is wider to even things out (those years are factory disc). Someone has probably used the tire wheel combo with the same or close drop. Do a search in the 67-72 forum and you should find the answer. If not, post your question there and someone can probably tell you.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Thread Tools | |
Display Modes | |
