01-14-2018, 10:14 AM | #1 |
Junkyard tips
Going to the junkyard, what is the easiest/safest way to remove windshield stainless trim?
Thanks |
01-14-2018, 10:20 AM | #2 |
Re: Junkyard tips
Good sharp utility knife. Cut rubber pop window out and remove trim. Not sure otherwise if you can remove window.
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
01-14-2018, 10:24 AM | #3 |
Re: Junkyard tips
sit on the seat , place both feet on top edge of windshield and push , wear safety glasses and gloves ,yes it will crack the glass work your way around the edge and it will push out . this is the reason they stopped flip forward seats without some type of latch and changed to a glue in windshield in 73 . people were getting launched thru the windshield in a crash. it used to happen a lot .
01-14-2018, 10:47 AM | #4 |
Re: Junkyard tips
Cut the gasket on the inside of the truck, then push the windshield out. Just pushing the windshield out without cutting the gasket is asking for the trim to get bent.
Oh, and I'm pretty sure they didn't start gluing windshields in trucks until '88 or so.....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
01-14-2018, 02:00 PM | #5 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Junkyard tips
If you want to save the windshield, and I would...Cut the gasket on the inside and push the glass out gently. Once the windshield is out, remove the gasket and trim, piece of cake. Windshield cracked already, same method minus the "gently"...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
01-14-2018, 02:03 PM | #6 |
Re: Junkyard tips
I popped mine out of my own truck (trying not to scratch anything) but cutting the rubber. There's no rush, cut it well. Cut away from yourself. don't pull hard on a razor knife that's pointed at your chest :-)
01-14-2018, 04:09 PM | #7 | |
Re: Junkyard tips
I agree that cutting the gasket near its bend on the pinchweld is the best way to remove the windshield and trim without damaging either.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
01-14-2018, 08:22 PM | #8 |
Re: Junkyard tips
if you want the trim then focus on that, often times you must sacrifice one to get the other. the gasket is done for son. with plenty of sharp blades, cut away the rubber and soak everything with liquid dish washing soap. who know? you may get lucky and save the windshield. but you still got to get it out of the yard, get it home and store it.
Betwix cup and lip lies many a slip |
Thread Tools | |
Display Modes | |
