01-14-2018, 03:15 PM | #1 |
70 c10 build
I posted this in the welcome boards but here is a link to my build
http://67-72chevytrucks.com/vboard/s...d.php?t=754801 |
01-28-2018, 10:27 PM | #2 |
Re: 70 c10 build
We finished the trailing arms. Waiting for a package from Ridetech and we can finish up the rear.
01-28-2018, 10:49 PM | #3 |
Re: 70 c10 build
The design/build of the center cross member was also started this weekend. Also sat a 350 on her for the first time to pull some measurements. I really stoked how everything is coming out. Ill keep updating as I get a chance.
01-29-2018, 09:14 AM | #4 |
Re: 70 c10 build
It looks like its coming right along. What wall thickness are you using for your cross member?
John J. Sales/Tech Direct Line: 812-481-4737 Office: 812-482-2932 JJohnson@ridetech.com Instagram: @ridetech_john |
02-02-2018, 07:47 PM | #5 |
Re: 70 c10 build
1.75 x .125 DOM tubing ,it was originally bought for a roll cage on a RZR.
02-05-2018, 12:28 PM | #6 |
Re: 70 c10 build
Well we worked on the cross member and finished the trailing arms. We also got the panhard bar on everything is coming together nicely
02-05-2018, 12:32 PM | #7 |
Re: 70 c10 build
I'd say everything is pretty square and level.
02-05-2018, 12:38 PM | #8 |
Re: 70 c10 build
Cutting the trailing arm brackets on the Plasma table
02-10-2018, 10:32 PM | #9 |
Re: 70 c10 build
Finished up the panhard bar and we capped off the frame notch. Going to tear everything apart finish welding, and get it off the frame table on to the rotisserie !
02-11-2018, 08:38 AM | #10 |
Re: 70 c10 build
Coming along nicely. I like those trailing arms. How much of a drop is built into them?
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
02-11-2018, 02:22 PM | #11 |
Re: 70 c10 build
The front is 5" the rear is 7" but it is set up, if I wanted to, to bag it and lay frame. I'm going to stay with the coil overs though. Put that extra money in the motor !
02-11-2018, 04:45 PM | #12 |
Re: 70 c10 build
Nice detail work! Following along
03-01-2018, 05:27 PM | #13 |
Re: 70 c10 build
Here's the latest guys. Finished mounting rear shocks. It took a while to gather up the material and tooling needed to make the stainless top mounts, but they turned out great. Then it was tore down again to finish welding and grinding. Hopefully the next couple weekends it is ready to spray.
Thread Tools | |
Display Modes | |
