01-27-2018, 12:44 PM | #1 |
bilstein shock question
Can you remove the upper mounts on these shocks so they are just eyelets like the bottoms of the shocks? If so, do you just unbolt them or do they have to be cut off?
https://www.ebay.com/itm/Bilstein-B6...ZZg~2w&vxp=mtr
RIZ 81 C10 short box 82 K5 Blazer |
01-27-2018, 03:53 PM | #2 |
Re: bilstein shock question
I think you'll have to cutoff a welded washer. then it will be just like normal.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
01-31-2018, 08:58 PM | #3 |
can anybody verify this? If a guy cut off the welded washer, would it slide onto an existing shock shaft mounted to the frame?
02-01-2018, 10:55 AM | #4 |
I know I've tried to remove the stud on one before & it was bonded to the bushing. As I tried pressing the stud, the entire bushing came out. I don't know if just some are like that or if it's a standard.
02-01-2018, 12:26 PM | #5 |
trying to find Bilsteins that are same as stock for my C10 but with open eyes in both ends.... for fronts and rears.
02-01-2018, 12:33 PM | #6 | |
If you need to remove the front stud from one of their shocks, you can try to cut & press the remaining portion of the stud out. If it's bonded & wants to come out as a unit, there's a simple fix. You can get some poly bushing halves to replace the bushing. Done.....
02-01-2018, 02:12 PM | #7 |
First.... I so appreciate the help.... where would i get the poly bushing for the shocks? Could I get poly or rubber bushings from Bilstein? I'm new to the whole frame up restoration world.
02-01-2018, 06:37 PM | #8 | |
https://www.summitracing.com/parts/p...iABEgKKqfD_BwE
02-02-2018, 10:11 PM | #9 |
put a screwdriver in between, and shoot a little pb blaster in there. they will come out. I had to move the sleeves on mine from top to bottom and that worked.
02-03-2018, 02:31 AM | #10 |
On Bilsteins? I did wd40 & a press. The entire stud/bushing pushed out together.7
02-03-2018, 02:08 PM | #11 |
yes on bilstein. they are the 7100 series so maybe different.
02-07-2018, 07:46 AM | #12 |
based on this info, I just bought all 4 and spent $300....... I'll let y ou know how it goes once they arrive.
Thread Tools | |
Display Modes | |
