![]() Join Date: Aug 2015
Source for 69-72 K10 rear axle U-bolt spacers?
My K10 has a 1970 chassis and I am looking for a source for rear axle U-bolt spacers. LMC shows them in their catalog (item 5 in pic below) , but they are not available. I have looked at a lot of vendors sites and haven’t seen them listed anywhere else.
Is this something I should look for using a WTB on the Parts Board? Rust has destroyed one of mine, but decent used ones painted up would be fine also. Any help appreciated. Steve/NH |
Re: Source for 69-72 K10 rear axle U-bolt spacers?
You could make those if you can't find them. Use flat stock, drill the hole for the center bolt then roll the outer ends using a vice & hammer (if you want to get fancy use a torch & a pipe to form the roll) You don't need to worry about the inside lips, the u-bolts will be positioned and held in place by the outer lips.
FWIW, I have a 70 & 71, both 3/4 ton 4wd's, neither have those plates, the u-bolts go directly around the spring pack. Don't know if that's factory or not, just the way they came to me. |
![]() Join Date: May 2001
I just bought a pair of those from LMC about 6 weeks ago for my 71 K/10. Weird they are unavailable now?
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
All about them K’s
![]() Join Date: Jun 2014
Id bet a spring shop can get them.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
I have a good used set that I would sell. Let me know if you are interested.
Thanks.
1970 K10 1970 C30 1973 C30 1980 K20 |
#6 | |
Thanks all for the replies.
I contacted LMC and they said that they lost their supplier for this part, and didn't know when it will be available again. Quote:
Can you PM me the details? Thanks, Steve |
Thread Tools | |
Display Modes | |
