Old 03-04-2018, 12:11 AM   #1
vweater2001
vweater2001's Avatar
69 Chevy windshield wipers
Got some rain out here in Cali so time to use the wipers. Noticed that the passenger side is barely touching the windshield when sweeping. I changed them out with a new set I had because it was time...wth is wrong that they are barely sweeping the windshield. Can’t figure it out?
"If you aint first your last!!"
1969 GMC C1500 Stepside Shortbed - daily driver
Mando
vweater2001 is offline   Reply With Quote
Old 03-04-2018, 09:22 AM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 69 Chevy windshield wipers
Check to see if the spring is still in the wiper arm. Or the spring is just weak, or that arm is bent. Is the arm all the way down on the shaft spline?
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 03-04-2018, 08:34 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Put some penetrating lubricant on the wiper arms where they pivot, when you pull them away from the windshield.... Then pull them up and let them back down a few times and see if that helps.
LockDoc
Leon
Old 08-09-2019, 12:11 PM   #4
vweater2001
Okay guys I know I hadn't gotten back on the thread with regards to the wipers...but I took them off and put the wiper arms back in, greased them up, put them back on the shafts and still not making enough contact on the windshield. The springs seem to be pretty strong still in my opinion, the wipers were working great up until I changed out the blades and now both sides are seriously not making enough contact...I got caught in the rain a few days ago and was like "Whoa, I need to get the wipers fixed ASAP." Any other tips or tricks I should use?
Mando
Old 08-09-2019, 12:23 PM   #5
HO455
Post Whore
HO455's Avatar
Are you sure you have the correct arms? Posting a photo may help us.
RIP Bob Parks.
Old 08-09-2019, 12:51 PM   #6
68 P.O.S.
Maybe wrong wipers? Try Trico Classic 33-150 wipers
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 08-09-2019, 08:58 PM   #7
vweater2001
I’ll post a picture tonight
Old 08-09-2019, 09:00 PM   #8
vweater2001
Wipers are correct as I purchased them from someone here on the forums and they were Terico brand you are saying. The blade bodies were metal not that cheap plastic you normally see.
Thread Tools
Display Modes
