Old 03-07-2018, 07:02 PM   #1
Help with Heat/AC
The system seems to work OK, but the issue I am having is that when I turn off the ignition switch, the fan continues to run unless I manually move the switch from AC to OFF.
I have traced out all the wiring and it appears good. Not hacked from what I can see. I have never known a truck to have the fan work with the key in the off position.
Any of you got ideas on what to check on?
Old 03-07-2018, 10:30 PM   #2
Goats86
Re: Help with Heat/AC
Might be the blower relay. If I remember correctly, it has full time 12 volts and the fan speed is regulated thru the ground at the switch.
Goats86 is offline   Reply With Quote
Thread Tools
Display Modes
