03-21-2018, 05:03 PM | #1 |
PS Pump Pulley Removal Tool 1972
Does anyone know of a PS Pump Pulley removal tool that will work on a 1972? All the ones I see listed talk about newer models, but not back to 72.
03-21-2018, 06:14 PM | #2 |
Moderator
Re: PS Pump Pulley Removal Tool 1972
Harbor freight has one for less than $20, I have used it many times over the years. I believe autozone loans it as well.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
03-21-2018, 06:27 PM | #3 |
Post Whore
I borrowed one from oreillys...
03-21-2018, 06:42 PM | #4 |
1974 & earlier GM power steering pumps have a 5/8" keyed & threaded shaft with a nut holding the pulley in place. Once that nut is removed, the pulley will usually just slide straight off the shaft. Although if there is a bit of rust holding the pulley in place, a puller tool (like the ones typically used with the 1975 & newer pressed-on pulleys) may be needed. And as long as the pulley hub has the necessary groove for the puller tool to fit into, the tool meant for the newer pressed-on pulleys should still work with the older pumps.
03-21-2018, 09:25 PM | #5 |
All about them K’s
NAPA sells one too
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
03-22-2018, 08:23 AM | #6 | |
motor exploder
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
03-22-2018, 02:00 PM | #7 |
Thanks for the input.
Thread Tools | |
Display Modes | |
