Old 03-21-2018, 06:47 PM   #1
Jim Boy
Smile 250 engine and Sea Foam?
I was wondering if anyone out there has used that Sea Foam product in the oil and gas on a 250 engine. If so what was the result and were you happy at the end? Have a good one eh!
Jim Boy is offline   Reply With Quote
Old 03-21-2018, 07:21 PM   #2
mikeshome
mikeshome's Avatar
Re: 250 engine and Sea Foam?
I use the sea foam fuel stabilizer all the time in all my engines seems to work very well.Do you have a problem or just preventative?Never used in the oil.
mikeshome is offline   Reply With Quote
Old 03-21-2018, 07:39 PM   #3
I guess the results will depend on the need a truck has. Some may notice nothing, trucks with fuel issues will run better, and trucks with gunked up heads/lifters should see a difference. Engine size has nothing to do with it.
Old 03-21-2018, 07:46 PM   #4
TCCGRIZ
I use it in all my older rigs . Works great , 396,350,292 engines
TCCGRIZ is offline   Reply With Quote
Old 03-21-2018, 07:51 PM   #5
a1vintage69
a1vintage69's Avatar
I highly recommend sea foam in the fuel tank. I bought a truck that would hardly run , it had been sitting for awhile and I dumped a can of s f in it and 5 gallons of fresh gas. Whalla, ran like a champ within 15 minutes.
a1vintage69 is offline   Reply With Quote
Old 03-21-2018, 09:45 PM   #6
Jim Boy
Smile Re: 250 engine and Sea Foam?
Thanks guys. With all answers being positive a fellow can't go wrong. I am getting a bit of carbon deposit at the end of the tailpipe and seeing that the engine is just purring fine I thought that I'd try some Sea Foam and maybe clean up some stuck part in the engine. I don't think it will hurt any other than explaining to the boss as to why I poured money into the truck with no results. Thanks again. HAVE A GOOD ONE!
Old 03-22-2018, 02:08 PM   #7
Alex V.
Alex V.'s Avatar
Seafoam is good stuff when used properly. 1 oz. per quart in the oil for 500-1000 miles before a change will help dissolve gunk. In the fuel it'll help capture and burn any water, and clean the carb. and intake side of the engine. Put 1-2 ounces down each spark plug hole and let soak overnight to clean gunked up rings - just crank it over with the plugs out to blow any leftover out, or you may hydro-lock if there's any liquid left in the cylinder. Expect lots of white smoke for a few minutes afterward.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Thread Tools
Display Modes
