Old 03-31-2018, 12:23 PM   #1
GBFD 453
GBFD 453's Avatar
Exhaust Size
I installed LS in my 71 LWB and need to put exhaust on. The muffler shop warned me of installing 2.5" pipes due to loss of torque, they recommend 2.25" pipe. Engine is fresh rebuild with GM hot cam and decent tune. Also flowmaster 40's exiting out the rear. Any input on loss of torque with larger pipes? Thanks
1971 LWB LS/350 Factory A/C
2002 GMC 2500HD 8.1
2005 Silverado BDS 6.5 with 35's
2012 Chevy Tahoe
GBFD 453 is offline   Reply With Quote
Old 03-31-2018, 12:37 PM   #2
davepl
davepl's Avatar
Re: Exhaust Size
Ignore them. That -might- matter for header tube primaries but no way it matters for exhaust, especially once you're 6-8 feet back down the system.
It will sound louder with 2.5s though, but I don't think you'll mind.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-31-2018, 12:55 PM   #3
kwmech
Re: Exhaust Size
Assuming dual exhaust, yes it can affect the torque, but I doubt you'll even feel the difference since stepping up into an LS platform
Old 03-31-2018, 02:08 PM   #4
Killer Bee
Killer Bee's Avatar
Re: Exhaust Size
I think some folks confuse the purpose of optimum diameter and length of exhaust tubing and colloquially refer to it as 'back pressure'
in almost all cases, the least amount of restriction is better due to increased flow..
performance adders like tubular headers, crossovers, etc. enhance the exhaust stream by drafting or scavenging from one another..
this 'tuning' is accomplished by arranging the appropriate diameter and length primary tubes into the collector for optimum efficiency..
the higher velocity exhaust stream in the primaries increases this effect in the collector..
'torque tubes' or header extensions are simply an extension of the collector to increase the efficiency of the scavenging effect..
mufflers and full length exhaust in any measure are simply to reduce/tune/adjust sound levels and add appearance features..
please let us know what you end up with, pictures are groovy too, good luck!
Old 03-31-2018, 02:53 PM   #5
hjewell2
hjewell2's Avatar
Re: Exhaust Size
Darn tootin the less back pressure the better, more important when running full system out the back and several bends to get there.
hjewell2 is offline   Reply With Quote
Old 03-31-2018, 03:06 PM   #6
7 Devils
7 Devils's Avatar
Re: Exhaust Size
Killer be is exactly right. Back pressure for torque is a myth and countless Dyno results have proven that. Go with what you like. Even though I like the Flow master's straight through designs out perform them.
Dan
Forgive my typos, big fingers and little Android digital keyboard....what a mess
06 GMC Sierra crew cab Z71 DD leveling kit, 34's, bumper, LED lighting. Still doing stuff to it.
67 El Camino Custom 300 Deluxe. In progress.
55 GMC 371 2 1/2 ton. Upcoming project.
7 Devils is offline   Reply With Quote
Old 03-31-2018, 04:17 PM   #7
GBFD 453
GBFD 453's Avatar
Re: Exhaust Size
Thanks everyone for the help. The truck goes in early next week and I should have it back for the weekend. I will try to get some pics up on the rack.
2002 GMC 2500HD 8.1
2012 Chevy Tahoe
Old 03-31-2018, 07:44 PM   #8
harpo231
harpo231's Avatar
Re: Exhaust Size
Loss at low end ... pick it up on top
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 03-31-2018, 09:33 PM   #9
jessemthompson
Re: Exhaust Size
Run 2.50, 2.25 will be too restrictive. That exhaust shop is probably making excuses cause 2.50 is harder to get over the rear axle on a lowered truck. I went to 3 shops before I found one who was capable of doing it.
jessemthompson is offline   Reply With Quote
Old 04-02-2018, 03:46 AM   #10
adricar1
Re: Exhaust Size
i second that i went 3 inch on a dropped truck took days to get a bend route over the axle
GMC K1500 1971 350 cu in th350 4wd
Bondo Bob c 10 1971 stepside th 350
c10 1970 350 cu in manual air con stepside.
adricar1 is offline   Reply With Quote
Old 04-02-2018, 03:47 PM   #11
Ekliptix
Ekliptix's Avatar
Re: Exhaust Size
This answer all your questions. Actual tested data. https://www.youtube.com/watch?v=_PVXvHkr-Vs
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline   Reply With Quote
Old 04-02-2018, 06:44 PM   #12
sprint_9
sprint_9's Avatar
Re: Exhaust Size
I was going to post that too, pretty cut and dry if you ask me. Now 3 inch is when things get really tight
sprint_9 is offline   Reply With Quote
Old 04-02-2018, 08:37 PM   #13
7 Devils
7 Devils's Avatar
Re: Exhaust Size
Good post! It's accurate up to about 650-700 genuine HP.
Dan
Old 04-02-2018, 08:53 PM   #14
'70_402
'70_402's Avatar
Re: Exhaust Size
The REAL question is.... has anyone run 3" pipe over the rear axle with a drop?? I've got a 7" rear drop and i'm not sure there is room... out the side before the tire??
'70_402 is offline   Reply With Quote
Old 04-02-2018, 11:10 PM   #15
Robznob11
Robznob11's Avatar
Wink Re: Exhaust Size
Lol I run 3" with dyno max bullets (18") but they are dumped before the axle. Sure I have a larger cam than you but I have so much tq ,the 345/55 drag radials beg for mercy.....these trucks will benefit from a little less tq down low and more top end hp ca use they are light in the rear....I think 2.5 is optimum for your set up.. if it were me I'd get a larger cam and even bigger exhaust. The LS motors love more cam
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 04-03-2018, 10:03 AM   #16
Ekliptix
Ekliptix's Avatar
Re: Exhaust Size
I have 3" dual on my lowered C10. The installer had to pipe down to 2.5" for over the axle, so I'm 3" from the headers, x pipe, to the front of the axle, then 2.5" over the axle and back.
Old 04-03-2018, 08:38 PM   #17
indymachinist
Re: Exhaust Size
2.5 too big??
I'm going single 4" into a 4" in dual 3" out straight thru muffler. ☺
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Thread Tools
Display Modes
