Old 04-01-2018, 06:07 PM   #1
damnyankee36
damnyankee36's Avatar
Bed Cross Sills Uneven
I am mocking up the bed on the 66 and noticed that the tops of the sills are in alignment from front to back except for the rear one. It's about 1/4"-3/8" lower than the front three.
It's been years since I last test fit the bed and I don't remember this issue back then.
Am I missing something here?
damnyankee36 is offline   Reply With Quote
Old 04-01-2018, 06:39 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Bed Cross Sills Uneven
Picture would help
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-01-2018, 08:33 PM   #3
damnyankee36
Here ya go. With a straight board laying across the front three sills, you can see the gap between the rear of the board and the rear sill.
Old 04-02-2018, 11:10 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Are all your panels and sills from the same truck? When I was redoing my bed in the '66 post accident, I realized my donor front panel and one sill was different. There was a steel floor available in the 70's which doesn't have the thickness of the boards, and the floor sat a bit lower...but otherwise they fit the same.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-02-2018, 11:23 AM   #5
PGSigns
PGSigns's Avatar
Were the bed sides assembled? My 66 was off just a little and the back has one 1/8" thick washer under it and I just pulled the boards down the last little bit.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-02-2018, 02:14 PM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
I would think that once the entire bed is put together you'd see another problem. I wouldn't fit the wood the way you have it now, things may change dimension wise once its all together.
Old 04-02-2018, 07:30 PM   #7
damnyankee36
Jimmy
At one point they were. Before I saw the gap you see in the pic, everything was bolted down and snugged and I noticed a small gap between the bottom of the bedsides and the rear sill. Right where the factory welded that small bead. I noticed everything was under stress as I was disassembled the bed. After seeing this I could see why.
Yes, everything is original to the truck except the bedsides. The front three sills are all the same height too.
Exactly my thought!
A simple shim at both attach points on the rear sill should take care of this but I'd like to why I am having this issue before I do.
Old 04-02-2018, 07:53 PM   #8
The Rocknrod
Moderator
Until it's all together you really dont know what you have. It's all a guess or shot in the dark. And I'm talkin no light!
Thread Tools
Display Modes
