Old member
I need to get the bowl of the tilt wheel column off and fixed. To make it a non automatic tilt. Anybody have a step by step instructions on how to do this with out taking it a part. Is there a way to do it without taking it a part? I can cut the hump out I think and the gear selector out but what do I need to fill it up and how? I have the turn signal part off and have no problem fixing it. I plan to body fill those up.
Any help guy's will be appreciated. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
People know me
Re: Tilt column info
I had a buddy do this, he cut off the hump and used kitty hair fiberglass. Other than being able to spin the cup, you could not tell.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
Old member
I plan to weld the bottom to the tube so it want rotate.
Metal doc did a great job on his. Maybe he can give some tips. Grind, clean, fiberglass, paint
But how to stop the cup from spinning?
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Thread Tools | |
Display Modes | |
