04-16-2018, 08:47 PM | #1 |
How to remove and install new Lug Studs DIY
Picked up some centerline wheels this weekend on my way down to Pomona swap meet this weekend. Tried installing today and my studs are too short. Anyone have a diy method to remove old studs and install the new longer ones? All while leaving rear axles installed as well as doing the fronts (drums all around).
Been shopping for studs and they are about $2.50 a piece so $50+ for 22 of them (6 bolt hubs and 2 of the driver rear studs have already been replaced with longer studs). |
04-16-2018, 10:00 PM | #2 |
Re: How to remove and install new Lug Studs DIY
Yep no problem, Get a big hammer and drive out the old ones. Then start the new ones end. Put a washer over the new stud. Get a stock lug nut and impact it on.
04-16-2018, 10:20 PM | #3 |
04-16-2018, 10:29 PM | #4 |
Buy a stud installer from matco or snap-on. Its has a bearing in it so no undue stress is put on the threads as you pull the stud through the flange. If you just do the washer make sure you use lots of lube and never tighten past when the flange of the stud touches rhe back of the axle. If you do it will stretch the stud and ruin b the threads.
04-16-2018, 11:10 PM | #5 |
You can also use et(extended thread) studs.
04-16-2018, 11:11 PM | #6 |
You can also use et(extended thread) wheel nuts
04-16-2018, 11:27 PM | #7 |
Not sure those would work on my wheels. My wheels have the angled surface that meets the lug but. If my wheels had the flat surface (that accepted a skinnier flat shank lug nut with washer) they would work. As trying to use my standard lug nuts maybe 4 threads are engaged. My drivers rear hub has 2 replaced studs which are about 1/4” longer. Those allow enough threads for the lugnuts to be safe.
04-17-2018, 08:28 AM | #8 |
The special installer would be nice or you can pull the axles and use a press which is the best way if you use really long studs.
But I do as above with a pair of washers with grease between them which creates a plain bearings. Then use a stock open ended lug nut you put on backwards so that the taper is up and the larger flat nut head is bearing against the washer. Then spin it down with an impact until the knurl is pulled through the axle and the stud head is flush against the back of the axle. Don’t over tighten as you can break the head off the stud.
04-17-2018, 08:57 AM | #9 |
Drift punch them out, knock new in from behind, draw tight with all lug nuts, use larger nut or socket for spacer if no thread to bottom, remove lug nuts, install drum/rotor and wheel. When you are slipping the new studs through, move right and left to feel the splines align and tap in easy to start them first. Then smack them in tight. You can use a fat punch to knock them tight as possible, but I always do the lug nut thing from the front after. I now have a press but have not needed to replace any studs since buying
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 04-17-2018 at 09:48 AM. |
04-17-2018, 09:04 AM | #10 |
I'd be afraid to bang on all the studs to get them out, and then use the impact to pull the new ones in. You run the risk of spinning the stud and then you're in trouble. Plus, if I recall correctly from doing my own studs, I dont remember there being enough room to get the old studs out the back and then the new longer studs in without pulling the axle out some. On mine, I just accepted that I had to pull the axles and ended up using a sleeve I made to press the studs out and in.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
04-17-2018, 09:07 AM | #11 |
The et lugnuts have a conical seat.
04-17-2018, 09:28 AM | #12 |
A stock open end lug nut.
04-17-2018, 10:39 AM | #13 |
Post Whore
Pay close attention to the size of the spline on the old studs. There are lots of different sizes and it is easy to get one that is too large or small. If you have access to a micrometer taken some measurements of the hole and the old studs before you go to the store.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-17-2018, 10:55 AM | #14 |
I had to replace studs on the roadside in a Blazer with Auburn Gear posi. I only had one jack so there was no spinning the axle. One stud was left intact and I had my lucky day since that was the one lined up with the wheel cylinder and the other five were clear to back out and go back in. All I had were my carpentry tools and my son had left the jack crank out. I took a pair of tin shears opened up to a cross and put the tip of one side in the slot in the jack to crank it up. Slow process but got it in the air. I had a straight claw hammer and my trusty drift punch. Got a ride to the parts store and back from a passer by, drew the studs up tight, put wheel on, and down the road I went.
04-17-2018, 11:13 AM | #15 |
Post Whore
Had a similar experience on the highway between Spokane and Moses Lake. Car began vibrating. Pulled over and found i had only one stud left on the right rear. I fortunately had more tools than you did, but no parts were to be had. I pulled one stud out of the other three wheels and installed them in the missing holes and got back home with 4 studs on each wheel. It wasn't very long after that I ditched the aftermarket wheels.
04-17-2018, 11:31 AM | #16 |
When you can buy a U-joint press or a full upright Harbor Freight press with jack for $99, I don't think there's a lot of excuse for hammering them out or impacting them on.
I had all 32 to do, and installed them by hand with a u-joint press. Pushed them out with a upright press. I had to drill for larger studs at the same time, but that's another story. Long story short, I don't think zipping them on with their nut is the hot ticket. It'll work in a pinch but might as well do it the "right" way if you're so inclined.
04-17-2018, 11:36 AM | #17 |
04-17-2018, 11:38 AM | #18 |
What kind of half-assery is this?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
04-17-2018, 11:51 AM | #19 |
Post Whore
In my mind installing them on the car is less of an issue. But removing them? I really don't like hammering on the axle when it is still on the vehicle. Depending on the type of axle the force of the blow is transferred directly to the bearing or the C-clip retainer in the differential. It doesn't leave me with a warm fuzzy feeling as to their future lifespan. But lots of folks have done it with no issues.
04-17-2018, 01:03 PM | #20 |
Thanks for all the input/advice guys. I have access to my friends air hammer and impact wrench (I have air at the house). I really don’t want to remove the axles etc.
The standard Dorman part for my truck is the stud size I need. Guess from the factory they were like 1/4” shorter? Picking them up from autozone after work and may get the air tools also. Maybe get started on getting a stud out this evening. Trying to keep at it everyday. This wheel thing has pushed back my gas tank relocation project. I will be glad to have this done. Question on he fronts (drums also). I haven’t pulled the front drums off yet. Am I going to have enough room to remove/install the studs on the fronts once the drums are removed?? |
04-17-2018, 02:06 PM | #21 |
Speaking with a friend who has previously installed wire wheels on an impala. He recommended gorilla lug nuts (I guess they have various shank lengths). I started looking into them, and it looks like Beadblaster may be onto something. I only need like another 1/4" to get enough threads engaged. These add that and a little more. Would be a heck of a lot easier than replacing all my studs.
https://www.ebay.com/itm/SET-OF-24-7...pXMVt5&vxp=mtr |
04-17-2018, 09:10 PM | #22 |
Found a tire shop with the right lug nut. Went home and tried it out. It formats great. Definitely engaging at least 8 threads. So I’ll have 24 new lug nuts tomorrow. Thanks for all the tips guys but these lug nuts saved me a ton of work.
04-18-2018, 06:34 AM | #23 | |
04-23-2018, 11:55 AM | #24 |
Well, I spoke too soon. The new lug nuts I purchased (with the 1/4" shank on them), fit great.... but on the box it say's "don't count the threads in the shank towards minimum safety specs". So, I'm back to swapping studs. The fronts I'm going to take off and take them to my friend with a shop press. The backs, I think I can get off with a Clamp and a properly place socket. I'm hoping that works and I can replace them the same way. If manual doesn't work, I'll go either air hammer and impact gun or possibly big hammer.
I'm not removing the rear axles. |
04-23-2018, 12:06 PM | #25 |
You dont need to remove the axles. Just do like i said in post #2.
Thread Tools | |
Display Modes | |
